AutoCAD Forum
Windows 2000 server
4 REPLIES 4
436 Views, 4 Replies
Windows 2000 server
we have bought 3 licenses fo this product:
AutoCAD 2014 Non-Language Specific Commercial Product Upgrade Windows From Previous Version(s) ACE
Could we install the new Network license manager on a Windows 2000 server?
Where we can find the software?
Best regards,
Massimiliano
4 REPLIES 4
rkmcswain
You'll have to check the system requirements for the NLM software, but I don't see why it wouldn't run on Win2k. It's a very lightweight app that doesn't need much in the way of resources.
It's on your install media, or if you downloaded, it may be a separate download.
See this for more details than you could ever need.....
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p/3...
R.K. McSwain     | CADpanacea | on twitter
in reply to: rkmcswain
Another little question.
If we install the new .lic file the users that have the old version of AUTOCAD don't work? Only the new installation can works correctly?
Thank you.
Best regards,
Massimiliano
rkmcswain
Get with your VAR to resolve this. It depends on whether or not you're on subscription, and other factors.
TravisNave
RK is right.  If you are under Subscription, you can use the latest version plus up to 3 versions back.  That means currently, your AutoCAD 2014 license can also run 2013, 2012, and 2011.
The license manager is not compatible with Windows 2000.  You need to run it on Windows XP/2003 or later.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
AutoCAD Inside the Factory
