AutoCAD Forum
Press and Drag Autosave hang
5 REPLIES 5
624 Views, 5 Replies
I haven't been able to find anyone else who has this problem but I have autosave turned off, yet every time I try to press and drag an object, ACAD2007 autosaves, and it takes 5-10 seconds. Very annoying and I can't figure out how to turn it off, or fix it so it doesn't hang. I don't know what changed but it hasn't always done this, and I'm not ready to reinstall, if that even fixes it.
5 REPLIES 5
pendean
What changed on your PC, or with your R2007 installation (add-on, tweak, freebie, update, downgrade, new PC, new OS, new profile, new AutoCAD profile etc.).
Software doesn't just break one day: press-and-drag should turn anything on, so you have something running that's helping things along for you.
in reply to: pendean
Thanks. It could be a network thing. I guess even though autosave is turned off, it's still kind of on, and there's no way to prevent it from autosaving when I press and drag?
pendean
They are not tied together: your autosave must be coming on at other times, or the delay is someting else altogether.
If you think the problem is network based, move your files to your PC, unplug from the network/internet, and test.
Alfred.NESWADBA
What exactly does AutoCAD write to the command-line when that happens?
It may be that AutoCAD does a normal save and not an autosave, I guess it's first necessary to know what type of save is it before starting to check how it's activated.
Also interesting: in every drawing? Also when you use e.g. DesignCenter and drag something into your current drawing?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Thanks for the reply. In the command-line, it says "_u DROPGEOM GROUP Specify Opposite corder:" Below it says "Saving..." with a progress bar. This happens whenever I try to press-and-drag any object in my drawing.
Forma Design Contest
AutoCAD Beta
