AutoCAD Forum
Autocad Electrical 2013 command
3 REPLIES 3
675 Views, 3 Replies
Hi guys,
I have a problem with explode command, because I want to explode a block with attributes without losing them. In Autocad 2007 I used to type in "burst" but in this version this command doesn't exist. Anyone can solve this problem?
Henrique.
3 REPLIES 3
Patchy
Install Express Tools, then you can have BURST command.
steve216586
Burst is an express menu command, did you install it with your autocad package? if yes, try to use the explode attribute to text from the express menu, if it works check the command line to see what the command is. I have the command on a machine with ACAD Elec 2014.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
I've read a tutorial explanning the instalation process of the express tools, but it didn't work for me. I tryed to load the expression tools by accessing the control panel and clicking on “Programs and Features” then "Uninstall/change". I clicked on "Add or Remove features" but there isn't the option "Express tools" in the check list. Can I download it?
Ps.: I am using the student version of Autocad 2013.
Thanks for yours comments.
Henrique.
Forma Design Contest
AutoCAD Beta
