we have bought 3 licenses fo this product:
AutoCAD 2014 Non-Language Specific Commercial Product Upgrade Windows From Previous Version(s) ACE
Could we install the new Network license manager on a Windows 2000 server?
Where we can find the software?
Best regards,
Massimiliano
Solved by rkmcswain. Go to Solution.
You'll have to check the system requirements for the NLM software, but I don't see why it wouldn't run on Win2k. It's a very lightweight app that doesn't need much in the way of resources.
It's on your install media, or if you downloaded, it may be a separate download.
See this for more details than you could ever need.....
Another little question.
If we install the new .lic file the users that have the old version of AUTOCAD don't work? Only the new installation can works correctly?
Thank you.
Best regards,
Massimiliano
RK is right. If you are under Subscription, you can use the latest version plus up to 3 versions back. That means currently, your AutoCAD 2014 license can also run 2013, 2012, and 2011.
The license manager is not compatible with Windows 2000. You need to run it on Windows XP/2003 or later.
