Rotate Drafting Patterns
Long time Wish List item:
Model Patterns can be rotated, why not Drafting?
We've got a lot of drafted details that would look a lot nicer if the patterns would line up with the elements.
56 Comments
pieter7
Completely agree. This would greatly reduce the amount of work that is needed to make a detail section look better. Now we model most of our casework, but in able to show up good in section views we need to go over it with detail components (most casework hatches like plywood etc are directional). If we were able to rotate the drafting patterns on view by view basis we could just go in there, rotate a few hatches and be done with it.
In order for it to work though, one should be able to rotate patterns on non-system families (for now we can rotate patterns on ceilings and walls but not patterns that are attached to a casework family (a splashing wall above a kitchen counter, a tiled worksurface on a kitchen island, wood veneer patterns, ...)
Alos, it would be great if drafting hatches would react to "align with element".
BethanyPritchard
Drafting patterns have the "Orientation in Host Layers" option that can be set to "Align with element" - but according to Autodesk help, this only works  when the fill pattern is used in walls, floors, roofs, ceilings...
I would love for this to work with detail components - and why not always?  Is there ever a time when we would NOT want a drafting pattern to stay aligned with the element when that option is set?
Tags (2)
This is total no-brainer. Make it so #1!
sasha.crotty
Thanks for your submission and votes on this idea!  We are evaluating where this request falls into our roadmap and will provide an update when we have made a decision.
The Factory
dannyjones3355
Revit needs the ability to alter the alignment of drafting patterns. Everything is based on starting @ 0 and there are times when that really doesn't work.
Tags (1)
dplumb_BWBR
hugha
You can create rotations from patterns with the HatchKit Add-In for Revit  available from the Revit Exchange.
Note that this does not cover dplumb's desire to rotate or translate instances of drafting fills as each amended view could require referring to a different new pattern.
The ability to rotate, translate or even scale each instance of a drafting fill would confer great flexibility where none is currently available.
harlan_brumm
We've completed our review of this idea. After investigating the effort required to implement this request, we unable to add it to our roadmap at this time due to other priorities. However, we think this is a great idea so we will reconsider it as we made adjustments to our roadmap in the future. Thanks for the submission and keep voting!
The Factory
JensDeSmedt
It wouldn't surprise me if this problem has the same cause as this issue:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
please allow to change the origin of the pattern and its direction
dplumb_BWBR
This is a duplicate of this Idea with over 200 upvotes
https://forums.autodesk.com/t5/revit-ideas/rotate-drafting-patterns/idi-p/6323029
Currently under "future consideration"
YES!
This is one of those obvious functionality issues with Revit that I am astonished exists.  Being able to rotate/align fill patterns in drafting views is a critical detailing requirement.
Rotating a drafting pattern would be so helpfull. If it's posible i want to scale them by viewscale too! https://forums.autodesk.com/t5/revit-ideas/change-the-scale-of-the-fill-patern-by-view-scale/idi-p/7...
I can't rotate drafting patterns.  For example- the oft mentioned plywood detail item- does not align to the direction it is drawn- so I am limited to a pattern that is either vertical or horizontal.  Drafting patterns should be fully rotational- so that when my plywood is at a 30 degree rotation- I can have a plywood pattern that is also at 30 degree rotation.
This is not the title I wrote- this is the title that autodesk suggested- apparently by reviewing the suggestion- it means I select the suggestion.  The title should be "Align or Rotate drafting patterns."
EdwinG
But the "title" is at this moment still a problem https://forums.autodesk.com/t5/revit-ideas/set-section-perpendicular/idi-p/7155751
And i like to see that patterns could be rotated.
dplumb_BWBR
I posted the same thing a while ago.
At the moment, it's on the third page of the "Top Voted" tab
For some reason it's marked as "Implemented, but I think that's a bug in the system somewhere. It should be marked as Archived.
The verbiage in the Autodesk reply says
"we are unable to add it to our roadmap at this time due to other priorities"
harlan_brumm
Status changed to: Archived
harlan_brumm
harlan_brumm
