Show only
Search instead for
you are right man! Not Only Dimension Even Grids will not Appear in Sections. Autodesk should think about on this issue it will help full for coordination also it Reduce more coordination Time weather its perpendicular or align to any object elements!
There are a few ways to rotate a section. The most common one is by using the rotate command and snapping to the tail endpoint. As you rotate, Revit will snap to perpendicular alignment to the wall. Here I made a screencast about this: https://autode.sk/2s8nw24
However, you need to be aware of this new thing in 2019, where Revit no longer have a problem creating dimensions on non-perp. sections, but this introduces a new problem, which is Revit allowing you dimension non-perp. sections!!!
