change the scale of the fill patern by view scale
The same table for line weight but then for fill patterns.
The fill patterns that we use for a simple 1:100 drawing are sometimes too dense for a 1:5 detail. drawing. If there is a simple table for fill patterns scaling by view scale, then we can easily solve this problem.
3 Comments
samuelsanf
This is the difference between Model Patterns and Drafting Patterns, Model Patterns scales with the model; meanwile, Drafting Patterns plot with the same dimentions related to de print (real world). So 1.5mm (related to paper) crosshatch in drafting pattern plot with 1.5mm of separation between lines in scale 1:5 and with the same separation on 1:1000
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/RevitLT-Customize/fil...
yeah i know the difference between them... but sometimes to make your drawings readable, you want to rescale the drafting patterns. right now we replace some components with filled regions, this can be solved in a smarter way in my opinion.
Kimtaurus
Being able to select model patterns for the cut pattern would already solve this.
