Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
2008 AutoCAD electrical
3 REPLIES 3
d.brewerUU5ME
313 Views, 3 Replies
d.brewerUU5ME
Observer
Observer
Somehow I installed a French version of 2008 Acad electrical. I cant figure out how to change it or if its even possible. I heard acad had language packs at one point but seemed liked after 2008. Please help!
Tags (1)
3 REPLIES 3
TravisNave
in reply to: d.brewerUU5ME
TravisNave
Language pack support came with 2013 releases.  Unfortunately, you will have to uninstall and reinstall the english version of 2008.  However, it is retired software and Autodesk no longer provides perpetual license activation for this software.  So unless you have an old perpetual network license, you might be out of luck.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Autodesk Forums:
d.brewerUU5ME
in reply to: TravisNave
d.brewerUU5ME
Observer
Observer
I do have a license key. However, the whole installation menu was in French. I did not see where to switch it. Is it possible to uninstall and re-install in English?
TravisNave
TravisNave
Yes, if you have an english installer.
Autodesk Forums:
Autodesk Forums:
Administrator Productivity
