Using Inventor Vault with files in server
Hello everybody
Please forgive me, but I just don’t know how to use “Inventor Vault”.
My issue this time is:
How could I use “Vault” if my Inventor had been installed in a “Stand Alone” version and all my files are in the network server?
I question it because my bigger assemblies make my PC performance work extremely slow so I think using Vault could solve this slowness.
TravisNave
Yes!  This is the purpose of Vault.  You want to *always* work locally, not over the network.  Sometimes collaboration makes that difficult.  Vault solves those problems.  You should really contact your VAR for more information.
Good Luck!
Autodesk Forums:
