Message 1 of 1
Cross-Part Projected Edges from within assembly environment
Looking for some help/guidance doing this.
Essentially what I'm doing is creating a macro that will allow a user to select a face, and based upon that face, will automatically create an offset plane and then project cut edges from in the assembly and then cut that out in order to make a slot/tab system more efficient.
Currently stuck at the part where i need to project the loop of the tab from the other parts in the assembly. See the code/example parts attached.
Dim oAsmDoc As Document oAsmDoc = ThisApplication.ActiveDocument Dim oFace As Face Dim oCmdMgr As CommandManager = ThisApplication.CommandManager oFace = oCmdMgr.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select Face to mate with tabbed plate") Dim oPartOcc As ComponentOccurrence oPartOcc = oFace.Parent.Parent Dim oPCD As PartComponentDefinition oPCD = oFace.Parent.Parent.Definition Dim oSlotPlane As WorkPlane oSlotPlane = oPCD.WorkPlanes.AddByPlaneAndOffset(oFace.NativeObject, "-1/64 in") oSlotPlane.Name = "SLOT PLANE" Dim oSlotSketch As PlanarSketch oSlotSketch = oPCD.Sketches.Add(oSlotPlane) oSlotSketch.Name = "Slot Sketch" Dim oSketchProxy As PlanarSketchProxy oPartOcc.CreateGeometryProxy(oSlotSketch, oSketchProxy) '''Option A'' Attempt at using direct calls oSketchProxy.ProjectedCuts.Add '''End option A '''Option B'' Attempt at using control definitions ' Dim oSS As SelectSet ' oSS = oAsmDoc.SelectSet ' ' oSketchProxy.Edit ' ' Dim oDef As ControlDefinition ' oDef = ThisApplication.CommandManager.ControlDefinitions.Item("SketchProjectCutEdgesCmd") ' oDef.Execute ' ' oSketchProxy.ExitEdit 'End option B'''
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
