File name not showing for .ipn files?
Message 1 of 8
I have created a title block which picks up the filename of a model and autofills in the title block, however when ever i drop an .ipn file into a new sheet it picks up the file name of the model within the .ipn file, is the way for it to pick up the .ipn file?
Replies (7)
Message 2 of 8
bradeneuropeArthur
Could it be that the ipn file is bom phantom?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
What does this mean...?
Message 4 of 8
bradeneuropeArthur
Does the ipn file have the ability to change the bom structure to normal?
In the document settings of the ipn.
Then Bill of material.
Then change to normal.
Save the file ipn.
Do not know if this is possible I am not at my desk
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
Cant find anything within the IPN file, any other suggestions
Message 6 of 8
bradeneuropeArthur
I think this is the default setting and nothing to do against it.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
MechMachineMan
The only unique information ipn's contain is the VISUAL INFORMATION required to make the exploded view. Everything else is pulled from the associated .iam.
Even if you could get the .ipn file name for in the drawing, it doesn't seem to make much sense to use it because it's just saying "Look at this pretty visual" then SEARCH for a different file to actually get any usable information. Therefore, it just makes sense to only really reference the file with useful information in - the .iam.
If you really wanted to be stubborn, you could probably figure out a way to do it with iLogic, but it would be more of a hack job than a proper solution.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 8 of 8
Thanks for the answer
