CommandDefinitions Property not available in C# but is available in VB.Net
LukeDavenport
LukeDavenport
Bit of a strange one this. The 'Item' property of the CommandDefinitions object isn't available when I'm in a C# project (see screenshot)01-C.png
But it is available as usual when in a VB.Net project - see screenshot01-V.png
I need to use this 'Item' property to access an Inventor command directly by name instead of having to loop through a couple of thousand commands to find the right one.
I'm using Visual Studio 2015 and referencing the 2018 Inventor interop. Can anyone replicate this (just create two new empty projects and paste two lines in) or shed any light on why this property is missing?
Luke
bradeneuropeArthur
I see the same issue!!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
LukeDavenport
Good, thank you for checking. Not sure how it is possible to expose a property in one .Net language, but not in another?
It appears you can see the other Read Only properties available for the CommandDefinitions object, just not 'Item'.
And its not just an intellisense problem, you can't compile if you try to go ahead and type it in anyway.
Anyone from Autodesk have any ideas?
nmunro
C# does not use the Item property to access members of a collection. You should be able to access a specific ControlDefinition by using something like
InventorApplication.CommandManager.ControlDefintions["control_defintion_name"].Execute
Neil
https://c3mcad.com
LukeDavenport
Neil that's it! I must have missed that in C# 101. Slowly getting rid of my VB blinkers 🙂
