Rectangular Pattern of Feature in Part - C# or .NET Example
I'm programming my first Add-In for Inventor 2017 in C#.
The purpose of the Add-in is to create a steel grate. I already have the rectangle with 1 "grate". But now I have to create a rectangular pattern.
But here I'm stuck, I can't find any example that makes any sense.
I tried to make an objectcollection of the grate extrusion feature, and add this to a rectangularpatternfeature.
But I'm not making any progress. Could someone help me out?
  private void btn_create_Click(object sender, EventArgs e)
            #region CREATE PART + GET UNIQUE FILENUMBER + SAVE PART
            PartDocument oPartDoc = (PartDocument)_invApp.Documents.Add(DocumentTypeEnum.kPartDocumentObject, _invApp.FileManager.GetTemplateFile(DocumentTypeEnum.kPartDocumentObject), true);
            try
                StandardAddInServer.VLT_Conn = StandardAddInServer.LogMeInVault();
                if (StandardAddInServer.VLT_Conn != null)
                    Autodesk.DataManagement.Client.Framework.Currency.FolderPathAbsolute fld = null;
                    fld = StandardAddInServer.VLT_Conn.WorkingFoldersManager.GetWorkingFolder("$");
                    StandardAddInServer.VLT_WorkingFolder = fld.FullPath;
            catch { StandardAddInServer.VLT_Conn = null; }
            if (StandardAddInServer.VLT_Conn == null)
                MessageBox.Show("Gelieve u eerst in vault aan te melden!", "Foutmelding", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
                return;
            string fileNumber = StandardAddInServer.FileNumber();
            string saveLocationPart = StandardAddInServer.fileLoc.Replace(System.IO.Path.GetFileName(StandardAddInServer.fileLoc), "PT" + fileNumber + ".ipt");
            #region SetProperties Iterate
            Inventor.Document doc = _invApp.ActiveDocument;
            Inventor.PropertySets oPropertySets;
            oPropertySets = doc.PropertySets;
            foreach (PropertySet oPropertySet in oPropertySets)
                if (oPropertySet.DisplayName.ToLower() == "design tracking properties")
                    foreach (Property oProperty in oPropertySet)
                        if (oProperty.DisplayName == oPropertySet.ItemByPropId[(int)PropertiesForDesignTrackingPropertiesEnum.kDescriptionDesignTrackingProperties].DisplayName)
                            oProperty.Value = txt_omsch.Text;
                            doc.DisplayName = txt_omsch.Text;
                            doc.DisplayNameOverridden = true;
                        else if (oProperty.DisplayName == oPropertySet.ItemByPropId[(int)PropertiesForDesignTrackingPropertiesEnum.kPartNumberDesignTrackingProperties].DisplayName)
                            oProperty.Value = txt_afm.Text;
                else if (oPropertySet.DisplayName.ToLower() == "summary information")
                        if (oProperty.DisplayName == oPropertySet.ItemByPropId[(int)PropertiesForSummaryInformationEnum.kSubjectSummaryInformation].DisplayName)
            #endregion
            oPartDoc.SaveAs(saveLocationPart, false);
            #endregion
            #region DRAW ROOSTER
            TransientGeometry oTG = _invApp.TransientGeometry;
            PartComponentDefinition oCompDef = oPartDoc.ComponentDefinition;
            Point2d[] oPoints = new Point2d[4];
            oPoints[0] = oTG.CreatePoint2d(0, 0);
            oPoints[1] = oTG.CreatePoint2d(calcWidth / 10, 0);
            oPoints[2] = oTG.CreatePoint2d(calcWidth / 10, calcLength / 10);
            oPoints[3] = oTG.CreatePoint2d(0, calcLength / 10);
            PlanarSketch oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes[3]);
            SketchLine[] oLines = new SketchLine[4];
            oLines[0] = oSketch.SketchLines.AddByTwoPoints(oPoints[0], oPoints[1]);
            oLines[1] = oSketch.SketchLines.AddByTwoPoints(oLines[0].EndSketchPoint, oPoints[2]);
            oLines[2] = oSketch.SketchLines.AddByTwoPoints(oLines[1].EndSketchPoint, oPoints[3]);
            oLines[3] = oSketch.SketchLines.AddByTwoPoints(oLines[2].EndSketchPoint, oLines[0].StartSketchPoint);
            Profile oProfile = oSketch.Profiles.AddForSolid();
            oProfile.AttributeSets[0].Name = "Length";
            ExtrudeFeature oExtrude = oCompDef.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, cb_rdikte.SelectedItem, PartFeatureExtentDirectionEnum.kNegativeExtentDirection, PartFeatureOperationEnum.kNewBodyOperation, 0);
            MessageBox.Show(oExtrude.FeatureDimensions.Count.ToString());
            oExtrude.FeatureDimensions[1].Parameter.Name = "DikteRooster";
            oExtrude.FeatureDimensions[2].Parameter.Name = "TaperAngleRooster";
            oSketch = oCompDef.Sketches.AddWithOrientation(oExtrude.StartFaces[1], oCompDef.WorkAxes[1], true, true, oCompDef.WorkPoints[1], false);
            oSketch.SketchLines.AddAsTwoPointRectangle(oTG.CreatePoint2d(0.7, 0.7), oTG.CreatePoint2d(3.8, 3.8));
            oExtrude = oCompDef.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, cb_rdikte.Text, PartFeatureExtentDirectionEnum.kNegativeExtentDirection, PartFeatureOperationEnum.kCutOperation, 0);
            oExtrude.FeatureDimensions[1].Parameter.Name = "MaasExtrudeDikte";
            oExtrude.FeatureDimensions[2].Parameter.Name = "TaperAngleMazen";
            oExtrude.Name = "Mazen";
            #endregion
            #region CREATE PATTERN
            ObjectCollection objColFeatures = _invApp.TransientObjects.CreateObjectCollection();
            objColFeatures.Add(oCompDef.Features.ExtrudeFeatures[2]);
            RectangularPatternFeature oRectFeature = oCompDef.Features.RectangularPatternFeatures.AddByDefinition();
            #endregion
            oPartDoc.Update();
            oPartDoc.Save();
            this.Close();
Thanks in advance
dgreatice
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-6D6F1140-F264-42E2-A0DB-4C967742267E
My example solution, but I'm using inventor 2014 and VBA:
https://forums.autodesk.com/t5/inventor-customization/rectangular-pattern-part-ilogic/m-p/7599859#M7...
When I see API inventor 2017 there are difference:
RectangularPatternFeatures.AddByDefinition(....) or
RectangularPatternFeatures.CreateDefinition(....) <-- Same like my example
but in inventor 2014:
Dim RecFeat as RectangularPatternFeatures
set RecFeat  = ....RectangularPatternFeatures.Add(...)
Maybe you can find any clue from my example.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Thanks for the push in the right direction.
This is what I came up with:
            ObjectCollection oObjColl = _invApp.TransientObjects.CreateObjectCollection();
            oObjColl.Add(oExtrude);
            RectangularPatternFeatureDefinition oRecFeatDef = oCompDef.Features.RectangularPatternFeatures.CreateDefinition(oObjColl, oCompDef.WorkAxes[1], true, 5, 3.8, PatternSpacingTypeEnum.kDefault);
            RectangularPatternFeature oRecFeat = oCompDef.Features.RectangularPatternFeatures.AddByDefinition(oRecFeatDef);
#endregion
Now I just have to find out how to create a pattern in two directions Smiley LOL
