Start External rule automatically at opening part from Content Center
Ezekiel12
Message 1 of 11
Ezekiel12
Is there any way how to run specific external ilogic rule always on opening ANY file from Content Center?
It can't be done by Event triggers in template, because its always different fot CC parts. So it has to be done somehow by external rule itself. But no idea how. Does anyone know?
thx,
Matt
Replies (10)
Message 2 of 11
bradeneuropeArthur
Better learn programming add ins.
This is much easier.
You are able to use event from inventor.
Also on placing Cc parts!
And you will see all the benefits!
If help needed please let me know.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 11
Ezekiel12
Well, Im sure addin would work in this, but I am not programmer, but I do use ilogi codes a lot, thats I at least ask here about ilogic if someone tried something similiar.
Addin could be solution, but its not 🙂
Message 4 of 11
bradeneuropeArthur
Could you use VBA?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 11
bradeneuropeArthur
The Cc parts are always placed in an assembly, right?
So you could create a rule in your assembly template only!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 11
Ezekiel12
Thats the thing. Its not.
Open > Open from CC
Message 7 of 11
bradeneuropeArthur
Cc parts as standsrd are always read-only!
What would you like to do with this file than?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 11
Ezekiel12
Please try that before helping. 😞
You CAN open and edit like this. That s no problem.
Message 9 of 11
bradeneuropeArthur
If they are used as custom yes to my opinion.
But as standard in the Cc folder not.
Hope you will find your solution to this.
Try only to help from my side!
This means also to guide you in a direction that is working and is not that complicated, and avoid you from problems I have seen over the years in inventor....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 11
Ezekiel12
Open > Open From CC
You can select CC part, select its settings, get numbering (from Vault for example), ave it as IPT (with CC template). Edit it, delete it, modify it, anything.
And I would need to my coworkers to figure out some rule that would run other rules when you open it like that.
Message 11 of 11
bradeneuropeArthur
Suggestion.
Could you use derive the Cc part into a normal part?
This will copy the Cc part. Set all invisible.
Then copy with i-logic all properties needed to the normal part from the Cc part.
Do you understand what I mean?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
