A thread to help get support on idea's you have in the Inventors Idea forum. We have installation threads, we have hardware threads, but how many people go to the Idea's forum and vote up suggestions ..
If you have an Idea posted, share the link here, so we all can review it, up vote it etc:
How to know everything is ballooned:
https://forums.autodesk.com/t5/inventor-ideas/a-way-to-know-if-everything-is-ballooned/idi-p/5600117
Video of it
http://www.yourcad.guru/balloon-check/
(Thanks to Curtis W for the coding)
Working in an IDW, a Next Page/Sheet Button vs having to keep double clicking on the next sheet
https://forums.autodesk.com/t5/inventor-ideas/next-page-sheet-idw/idc-p/5543711#M7422
When creating a Section View, have an option to turn off the Align option (I know you can do it via CTL) ...
I'm afraid, that this would flood the forums.
But it won't change the world.
Walter Holzwarth
Here are some of mine..
Don't waste the Force Effects code
Let me paint the inside of an electrical enclosure a different color than the outside
An easier way to fix assembly constraints when I change components
Steve Walton
Just hoping to get some more looks at the Idea' forum and for our ideas.
Example .... Curtis has some of his good ones in his signature:
An Inventor Improvement Idea that needs support:
I'm actually seeing an uptick in Votes from this posting already ...this might out great ...
@swalton Thanks for adding to it!! Exactly what I was hoping will happen!
Here are a few of my ideas.
https://forums.autodesk.com/t5/inventor-ideas/more-api-control-over-the-bom/idc-p/6494869#M13385
https://forums.autodesk.com/t5/inventor-ideas/new-or-better-mobile-app/idi-p/5813444
And something less serious, which has more votes and comments than most of my other ideas lol.
https://forums.autodesk.com/t5/inventor-ideas/update-splash-screen-each-year/idc-p/6754242#M15671
I feel like it is my duty to always shamelessly plug this idea:
Threads in Machining Environment.
Here are my ideas:
Joint improvements
https://forums.autodesk.com/t5/inventor-ideas/joint-improvements/idc-p/6260601#M11727
Dimension patterns
https://forums.autodesk.com/t5/inventor-ideas/dimension-patterns/idi-p/6592295
Line up dimension to baseline set
https://forums.autodesk.com/t5/inventor-ideas/line-up-dimension-to-baseline-set/idi-p/6594416
Remove override on multiple constraints
https://forums.autodesk.com/t5/inventor-ideas/remove-override-on-multiple-constraints/idi-p/6703139
Select origin to use for demoting parts
https://forums.autodesk.com/t5/inventor-ideas/select-origin-to-use-for-demoting-parts/idi-p/6892724
Show Relationships between selected components
patterned component constraints
https://forums.autodesk.com/t5/inventor-ideas/patterned-component-constraints/idi-p/5980982
Andrew In’t Veld
Designer
Here's one.. Yes just one..
Many times we are asked to weigh in (take a poll) on something for Autodesk.. What about having a poll on a list of "X" number of ideas that Autodesk is considering from the idea forum? That way we can tell Autodesk what they should focus on and what things we find "non-value added"...
Mark Lancaster
& Autodesk Services MarketPlace Provider
Like grab 10 ideas from the forum and have people poll on if they want it or not ?
bump
if you have idea's in the idea station, add them to the list:
I would think that IF AD was interested in what the users want, they can just look at the number of kudos given to an idea. I thought that was the idea of of giving Kudos in the first place. Why muddy it up with another poll?
Kirk
I've seen 100 kudos' and nothing happens.. I've seen less than 10 and it get under review.
If we can get any extra attention to some of these and maybe gain some interest on some really good ones, maybe just maybe they will get put into consideration sooner ...
So here are a few of mine that I would like to see implemented.
Tell us your actual votes, for creating a hitlist ..
I could think of an Excel file with these inputs for Inventor Ideas:
- Region (Forum - Customization - Installing and Licensing - Publisher (seems to be gone) ..)
- Topic
- Creator
- Entry date
- Total views by visiting date
- Total kudos by visting date
- Autodesk state of acknowledge
- Estimated date of integration
Walter Holzwarth
Additional comment: In Idea Station are several thousand entries. They'll never make it into a new release, that needs to be accepted.
But let's have a closer look at the top 200, sorted by votes.
Walter Holzwarth
And a few more of mine that would be really beneficial to anyone making idws:
Sweep a solid Body.
THE NUMBER 3 MOST VOTES FOR YEARS
https://forums.autodesk.com/t5/inventor-ideas/new-feature-sweep-solid/idi-p/5333169
