Inventor Forum
Autodesk Inventor Idea's needing Support Thread:
47 REPLIES 47
Message 1 of 48
mdavis22569
3471 Views, 47 Replies
A thread to help get support on idea's you have in the Inventors Idea forum.  We have installation threads, we have hardware threads, but how many people go to the Idea's forum and vote up suggestions ..
If you have an Idea posted, share the link here, so we all can review it, up vote it etc:
How to know everything is ballooned:
https://forums.autodesk.com/t5/inventor-ideas/a-way-to-know-if-everything-is-ballooned/idi-p/5600117
Video of it
http://www.yourcad.guru/balloon-check/
(Thanks to Curtis W for the coding)
Working in an IDW, a Next Page/Sheet Button vs having to keep double clicking on the next sheet
https://forums.autodesk.com/t5/inventor-ideas/next-page-sheet-idw/idc-p/5543711#M7422
When creating a Section View, have an option to turn off the Align option (I know you can do it via CTL) ...
https://forums.autodesk.com/t5/inventor-ideas/when-creating-a-section-view-have-a-option-to-turn-off...
Mike Davis
47 REPLIES 47
Message 2 of 48
WHolzwarth
in reply to: mdavis22569
I'm afraid, that this would flood the forums.
Smiley WinkBut it won't change the world.
Walter Holzwarth
Message 3 of 48
swalton
Here are some of mine..
Don't waste the Force Effects code
https://forums.autodesk.com/t5/inventor-ideas/2d-simple-simulation-working-model-mechanism-design/id...
Let me paint the inside of an electrical enclosure a different color than the outside
https://forums.autodesk.com/t5/inventor-ideas/part-view-reps-that-control-face-apearances/idc-p/6300...
An easier way to fix assembly constraints when I change components
https://forums.autodesk.com/t5/inventor-ideas/assembly-component-replacement-and-fixing-broken-const...
Steve Walton
Inventor 2024
Vault Professional 2024
Message 4 of 48
mdavis22569
in reply to: WHolzwarth
Just hoping to get some more looks at the Idea' forum and for our ideas.
Example .... Curtis has some of his good ones in his signature:
An Inventor Improvement Idea that needs support:
I'm actually seeing an uptick in Votes from this posting already ...this might out great  ...
@swalton Thanks for adding to it!! Exactly what I was hoping will happen!
Mike Davis
Message 5 of 48
pball
Here are a few of my ideas.
More consistent right click Ok/Apply/Cancel options
https://forums.autodesk.com/t5/inventor-ideas/more-consistent-right-click-ok-apply-cancel-options/id...
API access to auto sort on update in parts list
https://forums.autodesk.com/t5/inventor-ideas/api-access-to-auto-sort-on-update-in-parts-list/idi-p/...
More API Control over the BOM
https://forums.autodesk.com/t5/inventor-ideas/more-api-control-over-the-bom/idc-p/6494869#M13385
New or better mobile app
https://forums.autodesk.com/t5/inventor-ideas/new-or-better-mobile-app/idi-p/5813444
And something less serious, which has more votes and comments than most of my other ideas lol.
Update Splash Screen Each Year
https://forums.autodesk.com/t5/inventor-ideas/update-splash-screen-each-year/idc-p/6754242#M15671
Message 6 of 48
I feel like it is my duty to always shamelessly plug this idea:
Threads in Machining Environment.
        https://forums.autodesk.com/t5/inventor-ideas/thread-external-thread-in-welded-assembly/idi-p/368483...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 7 of 48
ACCEPTED
I up'd it ...
I liked that back when it came out ...
Cut, weld, drill, finish/thread  ....
Mike Davis
Message 9 of 48
Mark.Lancaster
in reply to: andrewiv
Here's one..  Yes just one..  Smiley Very Happy
Many times we are asked to weigh in (take a poll) on something for Autodesk..   What about having a poll on a list of "X" number of ideas that Autodesk is considering from the idea forum?  That way we can tell Autodesk what they should focus on and what things we find "non-value added"...  Smiley Wink
Mark Lancaster
Message 10 of 48
Like grab 10 ideas from the forum and have people poll on if they want it or not ?
Mike Davis
Message 11 of 48
mdavis22569
bump
if you have idea's in the idea station, add them to the list:
Mike Davis
Message 12 of 48
karthur1
I would think that IF AD was interested in what the users want, they can just look at the number of kudos given to an idea.  I thought that was the idea of of giving Kudos in the first place.  Why muddy it up with another poll?
Kirk
Message 13 of 48
mdavis22569
in reply to: karthur1
I've seen 100 kudos' and nothing happens.. I've seen less than 10 and it get under review.
If we can get any extra attention to some of these and maybe gain some interest on some really good ones, maybe just maybe they will get put into consideration sooner ...
Mike Davis
Message 14 of 48
WHolzwarth
Message 15 of 48
mcgyvr
Show decals in all drawing view styles (not just shaded only)
https://forums.autodesk.com/t5/inventor-ideas/show-decals-in-all-drawing-view-styles-not-just-shaded...
Option to Disable Sketch Scaling and Moving
https://forums.autodesk.com/t5/inventor-ideas/option-to-disable-sketch-scaling-and-moving/idi-p/6549...
Fix browser folder "limitations" with component patterns/cable&harness nodes
https://forums.autodesk.com/t5/inventor-ideas/fix-browser-folder-quot-limitations-quot-with-componen...
Message 17 of 48
WHolzwarth
Tell us your actual votes, for creating a hitlist .. Smiley Wink
I could think of an Excel file with these inputs for Inventor Ideas:
- Region (Forum - Customization - Installing and Licensing - Publisher (seems to be gone) ..)
- Topic
- Creator
- Entry date
- Total views by visiting date
- Total kudos by visting date
- Autodesk state of acknowledge
- Estimated date of integration
Walter Holzwarth
Message 18 of 48
WHolzwarth
Additional comment: In Idea Station are several thousand entries. They'll never make it into a new release, that needs to be accepted.
But let's have a closer look at the top 200, sorted by votes.
Walter Holzwarth
Message 19 of 48
karthur1
And a few more of mine that would be really beneficial to anyone making idws:
IDW Rotate view Improvement
IDW Improvement... Draft View Copy / Paste
Print "Current Window" should print the window
Message 20 of 48
Sweep a solid Body.
THE NUMBER 3 MOST VOTES FOR YEARS
https://forums.autodesk.com/t5/inventor-ideas/new-feature-sweep-solid/idi-p/5333169
