How many times have you needed to edit a part, then after the edit you get this.. "Missing or invalid origin for defining sketch coordinate system..."
This is because the sketch is using an EDGES to define both the coordinate origin and direction. When I see this error, I always redefine the sketch origin using the orgin Center Point. If I have to define a new axis direction, I will use one of the orgin axis for the definition. OnceI do this, I NEVER have to do it again for this part. It makes things so much easier, but it takes a few minutes to do if there are several sketches that fail.
In order for Inventor to be more stable, why not use the orgin center point and origin axis to define the sketch coordinate system?
If I never had to edit my parts, then the way it is now would be fine.... but not having to make changes is not how it is in the real world.
Kirk
