Installation & Licensing
Uninstalling LMTools 11.14.1.3
5 REPLIES 5
1349 Views, 5 Replies
We are attempting to uninstall LMTools version 11.14.1.3 so that we can install version 11.16 in order to activate our new license file.
1. OS is Windows Server 2012 R2
2. We have deactivated the license server.
3. We have attempted, unsuccessfully to uninstall and repair via add/remove programs and through the .msi file.
4. We get either a 2755 error or message saying the drive hosting the temp folder is full or unwritable (it isn't) when attempting these functions. We deactivated the license server before attempting the uninstall.
Is there a procedure for manually uninstalling this version of LMTools?
5 REPLIES 5
Mark.Lancaster
Mark.Lancaster
@Anonymous
Too me it sounds like you have permission issues.
Is this a server or PC hosing the license manager?
@TravisNave -->  Thoughts on this?
Mark Lancaster
@Anonymous
Mark Lancaster
in reply to: Mark.Lancaster
Server, working with admin privileges.
natasha.l
natasha.l
Hello @Anonymous,
The error 2755 and 1336 is a Microsoft error, please take a look at the Microsoft support page here for a suggestion.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Hello @Anonymous,
TravisNave
TravisNave
You're overthinking this. The installer from Programs & Features is just a
placeholder. You can update the license manager simply by installing over
in place or manually replacing the 4 .exe files that are extracted from the
.msi itself. Honestly, I have never used the installer itself and have
only ever just copied the files. Ignore the error and just get back up and
running right now.
Autodesk Forums:
running right now.
Autodesk Forums:
in reply to: natasha.l
Ended up being solved by our IT consultant, but I'm told that there was a folder set to read only that shouldn't have been. Thank you @Mark.Lancaster , @natasha.l  and @TravisNave for taking the time to look into this and offer suggestions
Administrator Productivity
