On 9/30/2014 I downloaded the AutoCAD Trial version AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us_Setup and because my old computer was running very slow afterwards, I have uninstalled it. As you know, during the installation process the Autodesk Application Manager comes along, uninvited, and now I cannot uninstall it at all. I have uninstalled everything else, or so I believe, however, when I try to uninstall the Autodesk Application Manager the mesage"Autodesk application Manager is still running on this computer. All instances must be quit prior to uninstall"
Nothing is running... I don't know what else to do to uninstall this final element... :(.
Do you have any other ideas that myght help me,Please?
Solved by mdavis22569. Go to Solution.
Solved by ukdxb012. Go to Solution.
Solved by TravisNave. Go to Solution.
Have you tried actually closing the Autodesk Application Manager from the systray before trying to uninstall it? You might also be able to kill it from the Task Manager processes. Worth a try.
THANK YOU THANK YOU I can't tell you how many hours we've wasted on this. Go to Task Manager/Details, then we selected AppMgr.exe and "End task" worked!
Please refer to the following Autodesk Knowledge Network Article's... http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Autodesk-Application-Mana... & http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-Silently-Uninstall...
You will also find a link below to my Autodesk Screencast on 'How to uninstall and reinstall Autodesk Application Manager'.
I'm trying to delete inventor from my computer and it won't uninstall from my computer it says: autodesk application manager is still running on this computer. all instances must be quit prior to uninstall. I had inventor closed and it still not letting me uninstall the application. How can I get that fixed?
I'm having the same issue and don't know how to do the process you explained. Thanks in advance
omg thank you very much!!!
I've been trying to do this for a long time and it bothered me when i turned my computer on it used to say "run autodesk..." but now it doesnt't. VERY BIG THANK YOU!!!!!!!!!!!!
u are awesome man. "Autodesk desktop app is still running on this computer, all instances must be quit prior to uninstall" this was bothering me like any thing
we need to end the process for AppMgr.exe from taskbar and then try to uninstall it.
Each time I try to uninstall this app i get the following message in the 'windows cannot find removeadappmanager.exe'. How do I resolve this? Thanks.
