desktop connector installation error,error 1625
362584813
362584813
I downloaded the exe installation file. After selecting the installation directory, the pop-up window will pop up at about 5%. I did not adjust the installation directory, and the problem has not been resolved.
I tried to restart the computer and turn off the anti-virus software, but the problem remains the same,
If someone has the same problem as me, I would like to know how to solve it. Thank you very much
mdavis22569
Can you make sure you have full ADMIN rights
What happens if you right click on the EXE and click the RUN AS ADMIN?
AKN, but it shows the wrong error:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
However it's about the permissions as I had mentioned
( the 1625 tends to be a permissions issue, and why I'm asking)
Mike Davis
rushabhthakkar_910
@362584813, Have a look at this..!!
(https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
I have also tried to run it by right clicking the administrator. The problem is still the same. Although my login account is the administrator account, I also tried to open the Administrator in the user of computer management. After the switch, the same error was reported
My problem has been found. I have installed other Autodesk software on my computer before, but it has not been uninstalled completely. I use AUTO_ Uninstller_ x64_ 9.6.01, uninstall and install again, and the problem is solved。
mdavis22569
Great to hear you're all set @362584813
Hoping you have a great 2023!
Mike Davis
