Hi guys,
I have a hard time accessing my AutoCad.
I verified my student status and also extended my license for a year. I also got an email from Autodesk that I can use the Autodesk programs. However, whenever I opened my AutoCad, it says my license has expired and need to get a new one. I really don't know what should I do because I already got my license.
Does anyone know how can I access it? I attached the images that you can refer.
Anna Chae
Solved by pendean. Go to Solution.
Educational Licenses and eligibility are explained here:
http://www.autodesk.com/education/free-software/featured
If you experience issues with requesting an education license or any additional problems, you can get in contact with the education support here:
http://www.autodesk.com/education/support/edu-contact-us-form
You can also try to reset the Autodesk licensing by running my script, found below in my signature line.
I already read and saw the link and followed it but didn’t work. On my account, it says I’m eligible and I can use it but on my AutoCad app, it says my license has expired.
I tried logging out and logging in but didn't work as well.. I also deleted and reinstalled too but same. I just checked I have my AutoCad on my purchased list (Image.5.). That means I can use AutoCad right?
Yes, I clicked it and as you can see (photo 6) there's AutoCad ver 2019~2022.
I clicked "view downloads". When I clicked left arrow, it comes like this (image 7).
Hi @tjsduddl97 - I'm just checking in to see if you need more help with this. Did the suggestion that @pendean provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Best,
I finally figured it out!
I deleted my CAD and reinstalled it. Then it seems everything works well.
Thanks for helping me to figure it out. I really appreciate it.
