Dear AutoCAD forum users,
Let me introduce myself. I'm Jasper and using point clouds to concept model installations in existing ships.
I am a new user to the AutoCAD 3D suites but am eager to start working with this software. However, if i install AutoCAD plant ultimate 2015 suite it gets stuck on the ReCap program. I require this program to convert point clouds.
What i tried so far:
Download Autodesk plant suite with Virtual agent. (Twice now to check for corruption)
Install (with administrator rights) with downloaded package (also twice)
Reinstalled complete package with uninstall help from the autocad forum( deleted all maps and autocad files + windows fixit tool)
I've managed to install the suite by deselecting the ReCap software. However in my case the whole suite is useless without said program. Is it a register problem or the point cloud software Scene conflict? Any help would be appreciated!
In the attachments a screenshot of install already run for 4 hours.
Sidenote: I couldn't download AutoCAD 2016 in the virtual agent. The error is seen in the second attachment.
Kind Regards,
Jasper
It's simply downloading the app. It is not stuck. Just wait it out.
Also, are you purposely installing ReCap? If it is just part of your suite installation and you don't need it, you can always unselect it before installation.
After another 8 hours of installing ReCap nothing happened. I looked at memory changes: none at all. I looked at network useage: none at all. It also doesn't use the processor. The status of the installation is: running. Does anyone have an idea what it could be?
In the attachments the picture of what the install looked like for 8 hours.
