When i try to install auto cad 2017.. it says that install autocad..it is not found in system..
sometimes it shows a path that doesnt exist in my system
Solved by TravisNave. Go to Solution.
@Anonymous hello, try to download from autodesk virtual agent , switch off all your antivirus program and firewall before downloading. your window OS atleast have SP1. see if this helps. thanks
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
