Installation & Licensing
566 Views, 4 Replies
I can't use AutoCad
I 've downloaded AutoCAD @017 to test, but I can't run it. It says that a .dll is missing, but it is in my computer, in fact, AutoCAD is the only application showing pronlem with that...
I really need help, the .dll in question is api-ms-win-crt-runtime-l1-1-0.dll, I've already unistalled and installed Visual C++ Redistributable, but the problem is still the same.
4 REPLIES 4
ennujozlagam
@Anonymous hello, make sure your computer the meet the requirements to run autocad if not you can check it HERE. trt to download from Autodesk Virtual agent check it HERE. try to switch off all your anti virus program and firewall before downloading and installation. clear all files in temp folder in c: drive those cannot delete just skip. hope it helps. thanks
imadHabash
Hi and welcome to AutoDesk Forum,
Lately we notice that Dropbox make a conflict with AutoCAD,( as at try not more) if it's already downloaded try to uninstall it.
Imad Habash
pendean
Post a screenshot of the exact error message please.
TravisNave
Start with my 2nd solution here and let me know.  I've had a lot of luck fixing this one lately.
http://forums.autodesk.com/t5/installation-licensing/api-ms-win-crt-runtime-l1-1-0-dll-is-missing-au...
Good Luck!
Autodesk Forums:
Administrator Productivity
