Installation & Licensing
267 Views, 4 Replies
DLL
4 REPLIES 4
TheCADnoob
Mark.Lancaster
@Anonymous
Welcome to the community..
You may be missing crucial windows update and I would install using the Virtual Agent Method or
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Mark Lancaster
in reply to: TheCADnoob
It's reaaly complicated i can't use these topics as guides.. however, thank you so much
TravisNave
Start here as a guide:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Error-1723-A-DLL-require...
That should get you on the right track.  If you still have issues, just repost here.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
