Installation & Licensing
Autodesk 2018 Direct Download Links (Until Available on Virtual Agent)
123 REPLIES 123
Message 1 of 124
TravisNave
220776 Views, 123 Replies
Issue:  You are having a download failure error, similar to previous releases, that are causing installation errors of your 2018 product.  However, the Autodesk Virtual Agent does not yet list the products available for 2018.
Work-Around:  Until the Virtual Agent is updated, we collective peers will try to provide Official direct download links from Autodesk.  This list may be updated as needed and links may or may not work as products are released.  You can also try the Browser Download method from your Autodesk Accounts Management page.
If you have an official direct download link, that is tested and working, or have a URL of a direct download link that should work once the products are released, then please feel free to update the links in the comments below.  Please only use official Autodesk links.  Piracy is not tolerated here.
AUTODESK 2018 DIRECT DOWNLOAD LINKS
AutoCAD 2018
English 32 bit
English 64 bit – Part 1
English 64 bit – Part 2
AutoCAD LT 2018
English 32 bit
English 64 bit
Inventor Professional 2018 x64
Part 1
Part 2
Part 3
Revit Live 2018
Download
Navisworks Manage 2018
Part 1
Part 2
Navisworks Simulate 2018
Part 1
Part 2
More to come soon...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Tags (1)
123 REPLIES 123
Message 2 of 124
Otto
in reply to: TravisNave
Hello TravisNave
It looks like you are having Revit installation issues. Community members with similar questions found the following article(s) useful:
For issues with Revit Server, please see the System Requirements for Revit Server.
If you are installing on Windows 10, please check that your product is compatible.
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 124
TravisNave
Here are more working links for other 2018 products:
DWG TrueView 2018
32 bit
64 bit
Inventor View 2018
Download
Recap 360 Pro
Download
Please come back to this thread for additional updates.
Autodesk Forums:
Message 4 of 124
TravisNave
Okay, @Mark.Lancaster, @DarrenP, @pendean, @Darin.Green...  Let's grow the list and link here for relevant 1603 download errors -- just like last year.  I figure these should start trickling in.  And they might expire and need updating as needed -- just like last year.
Autodesk Forums:
Message 5 of 124
Mark.Lancaster
@TravisNave  Why do you need our help?  Otto was right on the mark about you having an issue with Revit..  Otto should be able to assist.  Smiley Very Happy
My vote..  Make a Product Design and AEC collection with all the downloads for the products in one section..
Also thanks Travis for starting this..
Mark Lancaster
Message 6 of 124
TravisNave
in reply to: Mark.Lancaster
Yeah, @Otto is killing me.  I was hoping I could get some sort of exception to him on my threads.  With the 2018 product download failures, I feel like this will end up being a good short-term resource just like it was when Darin started it last year.  I should make a Macro to it now while I am thinking about it.  Perhaps we can get @natasha.l to help out with the list when needed?  Smiley Wink
Autodesk Forums:
Message 7 of 124
natasha.l
Hello @TravisNave,
This is great! Yeah, and as products continue to come out they can be added. Smiley Happy
Message 8 of 124
TravisNave
AutoCAD Raster Design 2018
32-bit
64-bit
AutoCAD MAP 3D 2018 (x64)
Part 1
Part 2
AutoCAD Electrical 2018
32-bit Part 1
32-bit Part 2
64-bit Part 1
64-bit Part 2
AutoCAD Mechanical 2018
32-bit
64-bit Part 1
64-bit Part 2
AutoCAD Architecture 2018
32-bit Part 1
32-bit Part 2
64-bit Part 1
64-bit Part 2
AutoCAD MEP 2018
32-bit Part 1
32-bit Part 2
32-bit Part 3
64-bit Part 1
64-bit Part 2
64-bit Part 3
Autodesk Sketchbook Pro Enterprise 2018 (x64)
Download
Inventor LT 2018 (x64)
Part 1
Part 2
Note:  I also want to point out that the Product Keys for 2018 are using the letter J this release year.  As in AutoCAD 2018 is 001J1.
Autodesk Forums:
Message 9 of 124
mdavis22569
Should it be noted that
AutoCAD 2018 and Windows 10 ..must be a 64 bit system.
  • Microsoft® Windows® 7 SP1 (32-bit & 64-bit)
  • Microsoft Windows 8.1 with Update KB2919355 (32-bit & 64-bit)
  • Microsoft Windows 10 (64-bit only)
Inventor:
Please make sure that you are installing the appropriate version of Autodesk Inventor software for your operating system. Inventor 2018 is only supported on 64-bit operating systems and cannot be installed on a 32-bit system.
Solution:
System Requirements for Autodesk Inventor 2018
Operating System ¹
  • 64-bit Microsoft® Windows® 10
  • 64-bit Microsoft Windows 8.1 with Update KB2919355
  • 64-bit Microsoft Windows 7 SP
Running into a lot of issues about this over the past few weeks. People are still trying ...and getting Error messages and asking for support on how to do it.
@Mark.Lancaster can verify a great one I had today.  "Why am I getting an error message while installing AutoCAD 2018 LT on 2008 R2 Server."
Mike Davis
Message 10 of 124
Scooch11
in reply to: mdavis22569
@TravisNave,
Thanks for starting the thread. The Virtual agent will be updated in the near future, early next month in the plan. Sorry for the delay.
Mike
Message 11 of 124
Darin.Green
@TravisNave
It seems you have all of the applications that are released thus far. I guess we'll need to post the new ones as they're release.
If this information was helpful, please consider using the Accept Solution
Message 12 of 124
Darin.Green
in reply to: Darin.Green
In addition to the virtual agent and the links posted above, here's a video showing the process to take via Autodesk Account.
Message 13 of 124
Darin.Green
in reply to: Scooch11
@Scooch11@natasha.l@Discussion_Admin
Can one of you temporarily pin this post to the top of the board until the Virtual Agent is updated?
Message 14 of 124
TravisNave
I was actually going to ask that, thanks!
I think I'm currently missing CFD and Vault. And I'm considering posting some from other languages for Alfred if I get time. Plus new releases as they drop... should be busy.
Autodesk Forums:
Message 15 of 124
Done
DA
Message 16 of 124
DarrenP
Vault 2018 Pro
Vault Pro 2018 Server
Vault Pro 2018 Client
Vault 2018 File Server
DarrenP
Message 17 of 124
DarrenP
in reply to: DarrenP
Advance Steel 2018 (64 bit)
Part 1
Part 2
DarrenP
Message 18 of 124
DarrenP
I added Vault Pro
DarrenP
Message 19 of 124
DarrenP
Vault Basic 2018
Vault Basic 2018 Server
Vault Basic 2018 Client
DarrenP
Message 20 of 124
DarrenP
i've done all the ones Travis has missed and have access to
i do not have any of the CFD 2018 downloads
DarrenP
Administrator Productivity
