Installation & Licensing
api-ms-win-crt-runtime-l1-1-0.dll is missing - AutoCAD 2017
53 REPLIES 53
Message 1 of 54
TravisNave
372401 Views, 53 Replies
Problem:  After successful installation of AutoCAD 2017 on my Windows 8.1 x64 system, I received this error on launch:
The program can't start because api-ms-win-crt-runtime-l1-1-0.dll is missing from your computer.  Try reinstalling the program to fix this problem.
acad.exe - System Error
This error did not appear on any of my Windows 7 x64 machines thus far.  I have not tested this on Windows 10 yet.
Reason:  From what I can tell, this is caused by the usage of the new Universal CRT | Visual C++ Redistributable that is part of Windows 10.  The good news is that it seems that the installation failures for not having C++ Redistributable installed might be resolved.  The bad news is, if the prerequisite does still fail and the program does install, it will not launch.
Possible Solution:  Here are some steps to take to try and resolve this issue:
Method 1:  This is the easy method.  Follow these steps if you receive the above error.  If it still fails, go to Method 2.
1.  Go to Windows Update and make sure that your computer is fully updated.  The Universal CRT should be delivered by this method.
2.  If not, manually download and install the Microsoft Visual C++ Redistributable for your version of Windows (likely x64)
For Windows x64:
http://download.microsoft.com/download/9/3/F/93FCF1E7-E6A4-478B-96E7-D4B285925B00/vc_redist.x64.exe
For Windows x86:
http://download.microsoft.com/download/9/3/F/93FCF1E7-E6A4-478B-96E7-D4B285925B00/vc_redist.x86.exe
3.  You might have to choose uninstall first before you can install the above downloads because of previous failed installs.
4.  Reboot then try to launch AutoCAD 2017 again.
Method 2:  If the above did not work, then here is my advanced solution.  The Universal CRT files are part of the Windows 10 SDK kit.  Installing this kit and placing the CRT DLL files into the AutoCAD 2017 folder seems to resolve the issue.
1.  Download and install the Windows 10 SDK kit:
https://dev.windows.com/en-us/downloads/windows-10-sdk
2.  Copy the entire set of DLLs from the resulting location:
C:\Program Files (x86)\Windows Kits\10\Redist\ucrt\DLLs\x64
3.  Paste the files into the location where AutoCAD 2017 is installed:
C:\Program Files\Autodesk\AutoCAD 2017
4.  Launch AutoCAD 2017 to complete the installation and licensing of the product.
Conclusion:  This is a very early and crude fix for this odd issue and I am only providing it as a work-around until I can find a more stable solution to post on the board.  I do not expect this to be an issue on Windows 10.
If anyone has anything else to add, please feel free to share.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Tags (1)
53 REPLIES 53
Message 21 of 54
in reply to: TravisNave
this error comes in my computer which is windows 7 32 bit please help me tp resolve this problem
Message 22 of 54
Mark.Lancaster
@Anonymous
Welcome to the community...
So may I ask...  Did you even try any of the information (or troubleshooting steps) that @TravisNave has stated in his article about this issue or did you just reply indicating you have this issue?
Mark Lancaster
Message 23 of 54
makingiqbal
iam iqbal
my autocad also same problem see the atched screenshot.
i ubdate my windows already. and i install  ms visual c++ x64
but cant unspecified errror
please help me
iam using windows 8
Message 24 of 54
@makingiqbal
How's is this the same error?   You have a totally different issue..  Smiley Wink
Anyhow to resolve your issue, download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
Message 25 of 54
I just downloaded the trial version of LT 2017, and ran into the error reported here. I've been trying to use the fixes suggested, and turned to method 2 as suggested by Travis when method 1 didn't work. Seems the Windows 10 SBK doesn't create a folder in the Program folder now, nor are there any DLL files that I could find. Looks as if the package has been modified.
Is there any other fix? The dialogue which appears when I try to launch LT suggests reinstalling the program. If I ran the installer again, would it try and plug any gaps? Alternatively, can I access older versions, or - if I bought a Windows 10 laptop, would I be able to download the software to a new machine using this account?
Thanks.
Message 26 of 54
Thought I should update my own status. After playing with the installer, with no improvement, I checked the MS website. A comment on there suggested, if the software requiring the extension, is on a standalone machine, downloading all outstanding optional Windows updates for v8.1.
I had 110 updates totalling almost half a gig, but an hour later, after restart, lo and behold! LT runs! I have no idea what was in all those updates, but something installed that fixes this problem.
Sorry I can't be more specific, but if you're not on a network, and you have some updates sitting around, download them and something good might happen.
Message 27 of 54
iam new in this software so please help me
my qiuestion is
i want to draw ibeam UB 203x133x25 kg/m
but my soft there is no detail about that example see my attached screenshot.
tq
Message 28 of 54
Mark.Lancaster
@Anonymous
Unfortunately you are in the wrong forum.  This forum is for users having issues when installing or licensing of their Autodesk product.  You are asking specific questions or how to workflows for a given application.  Please re-post in the proper forum.
Update:  Also (and this is very important)..  Please do not hijack another posting that has nothing to do with AutoCAD Adv Steel and change the subject matter.  May I ask why you even did this or even pick this posting to hijack?
Mark Lancaster
Message 29 of 54
i have the issue in windows 7 what can i do
Message 30 of 54
Thanks a lot for this solution ... Method 1: works with out any problem once you install -
  • Microsoft Windows 8.1 with Update KB2919355
    For Windows x64:
    For Windows x86:
    Good Luck!
Message 31 of 54
hello my name is aditya,
I have same problem with you. I already did windows update but still cant open autocad. After that, I tried method 2 but the problem is I cant download microsoft sdk. It said not capable for my computer. Its strange because I have windows 7 x64 bit and downloaded for that type. Would you like to help me please?
Message 32 of 54
NN
Message 33 of 54
hi, the problem doesn't seem to be resolved. Still having problem when launching my autodesk revit 2017 program. Can anyone help me ? I am having window 7 SP1 64bit. Thank you.
Message 34 of 54
For windows 7 Ultimate User just Update your window.
It will definitely resolve this issue.
Message 35 of 54
If you experience this error during the start of the program
ou need to (re)install the Visual C++ Redistributable for Visual Studio 2015, either via Windows Update or download and directly install the Visual C++ Redistributable
Read More
http://www.ithemesforests.com/how-to-fix-the-api-ms-win-crt-runtime-l1-1-0-dll-is-missing-error/
Message 36 of 54
I have the same problem of
1-1-0.dll missing from your computer
Windows 7
How to solve it
Methods 2 folder r not there in window 7
Plz help
Message 37 of 54
Please update your window 7 to window 7 service pack 1.
Message 38 of 54
Message 39 of 54
change service pack windows 7 to service pack 1
Message 40 of 54
Thank you so so so.. much
Administrator Productivity
