公告
Unable to uninstall Autodesk Application Manager
不适用
104,684 次查看
29 条回复
1 条消息(共 30 条)
不适用
On 9/30/2014 I downloaded the AutoCAD Trial version AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us_Setup and because my old computer was running very slow afterwards, I have uninstalled it. As you know, during the installation process the Autodesk Application Manager comes along, uninvited, and now I cannot uninstall it at all. I have uninstalled everything else, or so I believe, however, when I try to uninstall the Autodesk Application Manager the mesage"Autodesk application Manager is still running on this computer. All instances must be quit prior to uninstall"
Nothing is running... I don't know what else to do to uninstall this final element... :(.
Do you have any other ideas that myght help me,Please?
104,685 次查看
29 条回复
回复 (29)
2 条消息(共 30 条)
TravisNave
已接受的解答
Have you tried actually closing the Autodesk Application Manager from the systray before trying to uninstall it?  You might also be able to kill it from the Task Manager processes.  Worth a try.
Autodesk Forums:
3 条消息(共 30 条)
不适用
THANK YOU THANK YOU I can't tell you how many hours we've wasted on this.  Go to Task Manager/Details, then we selected AppMgr.exe and "End task" worked!
4 条消息(共 30 条)
不适用
This works follow the TaskManager Process......it works
5 条消息(共 30 条)
ukdxb012
已接受的解答
Please refer to the following Autodesk Knowledge Network Article's... http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Autodesk-Application-Mana... & http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-Silently-Uninstall...
You will also find a link below to my Autodesk Screencast on 'How to uninstall and reinstall Autodesk Application Manager'.
Hope that helps and good luck!
Duncan
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
6 条消息(共 30 条)
不适用
It keeps on saying quit all instances prior to uninstall an di do not know how how to do that
0 个赞
7 条消息(共 30 条)
不适用
I'm trying to delete inventor from my computer and it won't uninstall from my computer it says: autodesk application manager is still running on this computer. all instances must be quit prior to uninstall. I had inventor closed and it still not letting me uninstall the application. How can I get that fixed?
8 条消息(共 30 条)
不适用
If this didn't work, sorry, I don't know what else to try, sorry....
Go to Task Manager/Details, then click on AppMgr.exe and click "End task".
9 条消息(共 30 条)
不适用
Inventor 2015 uninstalled now I'm trying to install inventor 2014 so I
downloaded it and it says inventor 2014 language pack for this is already
installed. how do I uninstall the 2014 language pack from my computer?
10 条消息(共 30 条)
不适用
0 个赞
11 条消息(共 30 条)
不适用
I'm having the same issue and don't know how to do the process you explained. Thanks in advance
0 个赞
12 条消息(共 30 条)
不适用
You can find the Task Manager by clicking on the window in the bottom left corner of your screen, then typing in Task Manager. When I did this, AppMgr.exe was one of the choices. I wish I could help. I was trying to install Autocad 2015, I think, but this was almost 2 years ago. The software may have changed since then.
0 个赞
13 条消息(共 30 条)
不适用
Thanks a lot,i'ce tried it and successfully uninstalled autodesk application manager!
0 个赞
14 条消息(共 30 条)
不适用
omg thank you very much!!!
I've been trying to do this for a long time and it bothered me when i turned my computer on it used to say "run autodesk..." but now it doesnt't. VERY BIG THANK YOU!!!!!!!!!!!!
0 个赞
15 条消息(共 30 条)
不适用
Wow this works. thanks
0 个赞
16 条消息(共 30 条)
不适用
Oh, Thank You so much! TravisNAVE, it worked finally!!!
0 个赞
17 条消息(共 30 条)
不适用
Thank you very much. Task manager stuff worked perfectly.
0 个赞
18 条消息(共 30 条)
不适用
u are awesome man. "Autodesk desktop app is still running on this computer, all instances must be quit prior to uninstall" this was bothering me like any thing
0 个赞
19 条消息(共 30 条)
imlakhaniA6RPQ
Community Visitor
Community Visitor
we need to end the process for AppMgr.exe from taskbar and then try to uninstall it.
0 个赞
20 条消息(共 30 条)
johnmalone0
Each time I try to uninstall this app i get the following message in the 'windows cannot find removeadappmanager.exe'. How do I resolve this? Thanks.Autodesk Problem.jpg
0 个赞
