Reinstalled Revit but can view only.
janniemeyer
janniemeyer
After servicing my laptop I uninstalled and reinstalled Revit 2013. It opened in Viewer mode only. How can I rectify the problem?
Otto
Hello janniemeyer and welcome to the Autodesk community!
It looks like you need help uninstalling - or have issues that may be addressed by uninstalling - an Autodesk product. Community members with similar questions found the following article(s) useful: The following article(s) should help you resolve the problem:
Uninstalling a Product
Once your product is uninstalled, please try downloading your Autodesk Software using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
janniemeyer
Thanks for your advise. I figured out that Revit Viewer was my default.
I see that the Revit Viewer is currently opening my Revit files. This typically happens when one double-clicks on the Revit project file to open it up, and Revit Viewer is set to be the default opening program. Revit Viewer is included in the installation package, and gets installed together with Revit
I would suggest to rather open project files from within Revit’s Open command, as opposed to the method described above.
Sent from my iPad
TravisNave
If you do an Open With... then choose Revit and make it the default, it should always open with full Revit.  Just a thought.
Autodesk Forums:
