Announcements
[HELP] User is not being added in User Management
[PS] This website does not allow me to choose/find the correct 'board location' so I chose the most fitting, admin, feel free to move this to the correct board. I'm trying to add a user in user management, to be able to assign software to this user. The user has created his own Autodesk account. When I add the user, it thinks for a bit, and then goes back to the main user screen without any feedback. The user is not added, nor do I get any message it could not be found. When going to products->User acces: I add a user fill in details (email+first+last name) click save: The popup window fades out a bit, you see the circle "loading" animation, the popup closes to go back to the user access screen and keeps displaying the loading animation. Indefinatly. Bit anoying that the software is not working. If it would be a user error or a certain path has to be walked, it would have been nice to recieve some feedback. Regards.
Otto
Hello mroos and welcome to the Autodesk community!
If you’re having trouble with the activation email, please note that sometimes the email can be accidentally routed to your spam or junk folder. Please check there.
Also, please note that you should be able to access your download and activation information by logging into Autodesk Accounts.
If you cannot access software in your account and need to download it now, please go to the Virtual Agent.
If none of those items helped, please submit a support request as follows:
Students should request to have the confirmation email resent via this form.
If you are having trouble with your Autodesk Account or an eStore purchase, please visit our order support page where you will be able to chat with a representative or submit a support request.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Sadly it missed the mark. The problem is I can't add an user, to assign the software to.
