activation code
activation code
activation code
I have just purchased the Autocad LT for mac but can for my life not find the activation code thus i cannot use the program. I have spent an hour trying to find the damned thing here:
You'll access software downloads and activation information such as your Serial Number and Product Key at www.autodesk.com/account
But to no avail.
that is, my account works fine but i cannot find the place that says "your serial is this, your activation code is this"
Does anyone know how to solve this
Otto
Hello nilsPP37V and welcome to the Autodesk community!
It looks like you want to request an Activation Code. Community members with similar questions found the following article(s) useful:
How to request an Activation Code
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
it does not tell me anything
is there a phone number that can be called to get help on how to login?
camilo.lemos
Hi @Anonymous and welcome to the Autodesk Community!
Please check out this link mentioned by Otto, it should provide you with the info you need to find your serial number.
I hope this helps!
Camilo Lemos
