License is not valid
ROBERTHAIGHT1851
ROBERTHAIGHT1851
I am a long term autocad user in my architectural practice. As I near retirement, I have decided not to pursue my subscription. I understood that since I purchased autocad previously I would be able to continue to use what I have. I got some kind of update thing the other day. Now when I try to load Autocad I get a message that my license is invalid.
How can I get back to my last purchased version?
If this is the wrong place to ask, would you please direct me to the correct one? I no longer have an "authorized reseller" to contact
Thank you
Robert Haight,
Otto
Hello ROBERTHAIGHT1851
It looks like you're getting an "Invalid Serial Number” message or having trouble with your product key while trying to register and activate your Autodesk software. The following article(s) should help you resolve the problem:
Click Top reasons why you may get a Serial Number Error during Activation
And check Error: "Invalid serial number" (standalone activation)
For product key information: Finding Serial Numbers & Product Keys
If you’re having an issue with your product key, please make sure that you are using the correct one for your product (especially if your product comes from a suite). Finally, you should type then numbers and letters in. We do not recommend copy/paste.
If you are still having issues activating your product, you may visit our Activation Contact Us page and submit your inquiry there.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
ROBERTHAIGHT1851
If you had an active subscription and no longer continue with it..  It means that you are only entitled to use the version that is currently released by Autodesk when you went off subscription.
Not sure what version you are talking about or when you went off subscription, but it want to go back to the legacy version you basically have to get back on subscription.
Mark Lancaster
ROBERTHAIGHT1851
I understand the legacy question. I am not trying to get new versions, just use the earlier one.  My subscription just lapsed in January so I have ACAD 2015. I was able to find my serialnumber and product key and used them to get back to work.
I will need to better understand what the popup Autodesk Manager is doing so I don't get into the same situation again
Thank you for the assistance
TravisNave
You might consider disabling and/or uninstalling the Autodesk Manager.  It's just going to be bothersome and useless for you being off Subscription.
Autodesk Forums:
hello,
I am so stressed how to fix my problem in maya application, i don't know if the problem is in the license. I was updated my computer yesterday and my maya application is doesn't work anymore, everytime i opened it there has information my student file version has been saved and everytime ill open a new file, this information always came up and i couldn't work. and I was re installed the other version of maya but still problem came up. could you help me how to fix it?
