Autodesk Licensing Modifier Tool
tobias_wiesendanger
Message 1 of 15
tobias_wiesendanger
I wanted to share a tool that I started last year and just updated for 2021. Many of you probably already experienced the new tool to change / reset and modify licenses for 2020 and now 2021 products. It can be a bit overwhelming and even if you know what you do ,it costs alot of time to get all the information.
If you dont know what im talking about at this time, then check out this links:
How to change or reset a license for Autodesk software
So what I did is to create a UI for this exe. You no longer need to type in any command. Just search your product, decide what to do with it and click run.
If you want to, you can check out the code behind it, modify it whatever you would like to do with it or just use it by downloading the release from github. Product Keys for 2021 are guessed, because there is no updated list yet.
Download
Helpfile
Feel free to provide some Feedback here if something could be improved.
regards
Tobias
Replies (14)
Message 2 of 15
tobias_wiesendanger
I did get some messages about it being blocked. It is not signed so you get a warning message from defender which you need to allow if you want to run it. Also on some systems some library dll files get blocked and you need allow them manually.
You can find those files in res\assembly.
Maybe someone that tested it can post here that it is safe.
regardss
Tobias
Message 3 of 15
mdavis22569
maybe see about adding this to the Autodesk App store ...
Honestly I'd be nervous downloading / installing anything that could have access to licensing info from someone I don't know.
Not saying you're app isn't a great idea.  ( I've long been suggesting that a tool is needed like this vs trying to get NON-PC people having to get into the registry and other places to reset / resolve licenes)
Mike Davis
Message 4 of 15
tobias_wiesendanger
Yeah I get that. I probably would be a bit nervous to.  I was hoping somebody with some coding knowledge could check the code. In the end it does nothing more than creating a textstring to supply the adskhelper.exe which is delivered by autodesk.
But yeah I get the point. I think I look into the Autodesk App Store.
thanks
Tobias
Message 5 of 15
mdavis22569
I like the concept ...
While I get the new licensing, I'm not a fan of how complex it is when resetting it is required.
Travis made a quick similar tool.   I've used it / recommended it .. .because of how small / simple it was.
Mike Davis
Message 6 of 15
j_weber
Hi @tobias_wiesendanger
really great work.
I think it is better to have a tool like this with a gui like a command line batch tool.
thanks for sharing
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
Message 7 of 15
j_weber
Hallo,
is there a update so that the fantasic tool works with 2022 progamms.
Jörg Weber
Message 8 of 15
tobias_wiesendanger
Hi Jörg
Yes there is. Checkout the release page on the github.
https://github.com/TWiesendanger/ADSKLincensingModify/releases
regards
Tobias
Message 9 of 15
bonjour
y a-t-il une mise à jour pour les programmes 2022.
Message 10 of 15
j_weber
Hi Tobias,
thanks a lot.
The tool is very helpfull
greetz from germany
Jörg Weber
Message 11 of 15
j_weber
Hallo Tobias,
new year but same question like last year.
Is there an Update from your very helpfull programm for the 2024 programms
greetz from germany.
Jörg Weber
Message 12 of 15
tobias_wiesendanger
Hey Jörg
Yes there is. I rewrote it completly and you can now find it in microsoft store.
regards
Tobias
Message 13 of 15
j_weber
Hi Tobias,
great.
Thank you
It helps me often in my work.
I rate it with 5 Stars
best wishes and a nice long weekend.
Jörg Weber
Message 14 of 15
TravisNave
It's so much prettier than my command line version.  😂
Autodesk License Reset ToolAutodesk License Reset Tool
Nicely done.
Autodesk Forums:
Message 15 of 15
tobias_wiesendanger
Haha. Thanks. Im still looking at your tool from time to time 😃
