Error installing Fusion 360: SSL: CERTIFICATE_VERIFY_FAILED (_ssl.c:548)
Message 1 of 9
Good Afternoon,
I have attempted to install Fusion 360 and get the following error:
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:548)
Attempted all Known fixes in forum adn KB articles.
Log is attatched
Thank you.
Replies (8)
Message 2 of 9
TravisNave
You have checked this:
https://forums.autodesk.com/t5/design-validate-document/error-installing-fusion-360-ssl-certificate-...
and this:
http://forums.autodesk.com/t5/design-validate-document/issue-installing-fusion-360/td-p/5914828
My understanding is that this issue has been resolved already.  Sorry that you are still getting it.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 9
brianrepp
Hi @Anonymous - you should be receiving an email shortly from one of our developers to help diagnose and get you back up and running.
Message 4 of 9
Hi
I've just gone back to use Fusion after several months, It kept failing to update so I uninstalled and went to reinstall and got the same error message. Log file included below. Is their a solution? I've attempted all the solutions that I could find on the Forum.
Message 5 of 9
baribak
Can you try restarting both your computer *and* your network router and see if it helps?
Kevin Baribault
Fusion 360 Quality Assurance
Message 6 of 9
hello I have the same problem, fusion 360 keeps failing to update, so I uninstall it. and now I can't install again
my error is nested asn1 error (_ssl.c:3947).
can anybody help, please?
Message 7 of 9
baribak
Sorry to hear of the trouble. Can you try this:
In File Explorer right-click on the Fusion 360 Client Downloader file and choose Run as Administrator.
If that's unsuccessful try:
  1. Open the CMD window
  2. Navigate to the /Downloads folder.
  3. Enter this (include quotes):
  • "Fusion 360 Client Downloader.exe-c" or "Fusion 360 Client Downloader.
Hope this helps.
Kevin Baribault
Message 8 of 9
Nikola_Perunmoto
Same problem. Reinstalled it and I am trying to install it again. Receiving this message.
Here is log file.
Message 9 of 9
baribak
Not sure if this was solved but one thing it could be is a corrupt or expired certificate.
If so try clearing your certificates. You can do this through Manage Certificates (certmgr).
Hope this helps.
Kevin Baribault
