Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
MAPCSLIBRARY Errors and Omissions
Pointdump
Consultant Consultant
Message 1 of 57
Pointdump
This is an attempt to list errors and omissions in MAPCSLIBRARY.
The Tern Island 1961 Datum, Code: Tern61, shows an EPSG Code of 6707. It should be >>>EPSG:4707<<<. The EPSG site erroneously also lists the Tern Island 1961 Datum as >>>EPSG:6707-datum<<<, so it's not completely Autodesk's fault. EPSG:6707 should be >>>RDN2008 / UTM zone 32N (N-E)<<<.
To be honest, I don't understand the distinction between a Datum and a GCS(Geographic Coordinate System) in MAPCSLIBRARY. Feel free to school me.
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Replies (56)
Message 21 of 57
Pointdump
Add EPSG:4647 ETRS89/UTM zone 32N (zE-N), as noted in >>>This AKN Article<<<. Topic came up in >>>This Thread<<<.
Dave Stoll
Las Vegas, Nevada
Message 22 of 57
O_Eckmann
Hi @Pointdump ,
In the AKN Article there is a mistake in scale reduction between texte written and screen capture.
In texte it's written 0.996    (only 2 times number 9)
In screen capture there is 0.9996  (3 times number 9)
Which is good?
Olivier
Olivier Eckmann
Message 23 of 57
Pointdump
Hi Olivier,
I noticed that too. A typo maybe?
I went with the "official" >>>EPSG:4647 ETRS89/UTM zone 32N(zE-N)<<< which shows:
PARAMETER["scale_factor",0.9996]
Dave
Dave Stoll
Las Vegas, Nevada
Message 24 of 57
ChicagoLooper
Duplicate post 
Chicagolooper
Message 25 of 57
ChicagoLooper
The author of that AKN will confuse readers. Compare the EPSG codes. The title should show the correct one which is 25832.  The AKN has a typo and shows the wrong one: 28532
Misinformation? Yes.
Proofreading? Not so much.
Chicagolooper
Message 26 of 57
Pointdump
@ChicagoLooper,
I noticed that neither EPSG or MAPCSLIBRARY had 28532. I didn't tumble to the switched numbers and just went with ETRS89.UTM-32 in Map's Library. Good eyes.
Dave
Dave Stoll
Las Vegas, Nevada
Message 27 of 57
Pointdump
From >>>this post<<<, to fix >>>this -32,000,000 Meter problem<<<, add >>>EPSG:4647<<< to MAPCSLIBRARY. Workaround for now is to add as shown >>>here<<<.
Edit: This post is a duplicate of an earlier post, but with more info and links.
Dave Stoll
Las Vegas, Nevada
Message 28 of 57
Pointdump
Hover your cursor over the "Elliposid" symbol. Oopsie!
I'm using 2022, so this might have been corrected in 2023.
Dave
Dave Stoll
Las Vegas, Nevada
Message 29 of 57
Pointdump
Amtrak Coordinate System. From >>>This Request<<<.
I found details >>>Here<<<.
Dave Stoll
Las Vegas, Nevada
Message 30 of 57
Pointdump
With the nice Transformation Tool in Civil 3D being able to, in theory, transform vertical datums, MAPCSLIBRARY should include coordinate system with vertical definitions. Like >>>EPSG:6653<<<, NAD83(CSRS) / UTM zone 10N + CGVD2013 height. When I do a search for EPSG:6653, MAPCSLIBRARY shows ITRF94 Datum. But ITRF94 should be >>>EPSG:8994<<<.
If I search for NAD83(CSRS)/UTM zone 10N, I find CSRS.UTM-10N, which shows EPSG:3157. But let's compare WKT listings.
MAPCSLIBRARY:
TOWGS84[0.0000,0.0000,0.0000,0.000000,0.000000,0.000000,0.00000000]
EPSG:
TOWGS84[-0.991,1.9072,0.5129,-1.25033E-07,-4.6785E-08,-5.6529E-08,0]
Transformation to WGS84 should use the CSRS GSB file for British Columbia, so at this point my head is spinning.
Dave Stoll
Las Vegas, Nevada
Message 31 of 57
Pointdump
From >>>This Thread<<<, the StevensMN-F Coordinate System is not correct.
The coordinate system definition >>>Here<<< agrees with >>>ESRI:103783<<<. There are 2 problems with the MAPCSLIBRARY definition. First one is easy to fix. The extents are just flat wrong and don't cover Stevens County, Minnesota at all.
The second problem is that Minnesota uses a different size Ellipsoid than NAD83:
Semi-major Axis (meters): 6378502.761
Semi-minor Axis (meters): 6357116.84
Dave Stoll
Las Vegas, Nevada
Message 32 of 57
Pointdump
Definition of Terms are wrong in the Definition of GRS1980 Ellipsoid.
Equatorial radius should be Semimajor axis of the geodetic ellipsoid
Polar radius should be Semiminor axis of the geodetic ellipsoid
I know that's a quibble. I'm getting my terms and formulas from James Stem's white paper >>>Here<<<.
Inverse flattening should be just "flattening"
Flattening is not 0.00335281068118332. It is 0.00335281068118329
Eccentricity squared shows 0.0818191910428279. This number should be called First eccentricity.
And Eccentricity squared should indicate whether it is First or Second Eccentricity squared.
First Eccentricity Squared = (a^2 - b^2)/a^2 = 2f - f^2 = 0.0066943800229028
Second Eccentricity Squared = (a^2 - b^2)/b^2 = e^2 /1 - e^2 = 0.0067394967754810
First eccentricity of the ellipsoid = sqrt(2f-f^2) =0.0818191910428277
Dave Stoll
Las Vegas, Nevada
Message 33 of 57
Pointdump
Still misspelling Ellipsoid as "Elliposid" in 2023 MAPCSLIBRARY.
Dave
Dave Stoll
Las Vegas, Nevada
Message 34 of 57
Pointdump
Unable to define projection parameters with "Oblique Mercator" projection in MAPCSLIBRARY. Page is blank.
Dave Stoll
Las Vegas, Nevada
Message 35 of 57
Pointdump
Problem posted >>>Here<<<.
PT-TM06/ETRS89 is a bad definition in MAPCSLIBRARY.
ETRS89/PT-TM06 more closely matches >>>EPSG:3763<<<.
Dave Stoll
Las Vegas, Nevada
Message 36 of 57
rmacan
I stopped holding my breath for EPSG:6150 over five years ago. It's almost like it's....no one's job.
Message 37 of 57
Pointdump
Hi Randy,
Civil 3D and Map 3D can't do anything with the vertical part of a Compound Coordinate System like >>>EPSG:6150<<<, but you can add the horizontal part as a custom coordinate system. Strangely, if you punch in 6150 in MAPCSLIBRARY you get 2 listings for datums, neither of which is EPSG:6150.
While more coordinate systems are added each release, Autodesk really needs to have someone go through MAPCSLIBRARY from top to bottom and correct things like this.
Dave
Dave Stoll
Las Vegas, Nevada
Message 38 of 57
Pointdump
The Library doesn't have >>>EPSG:6703<<<, noted in >>>This Post<<<.
Dave Stoll
Las Vegas, Nevada
Message 39 of 57
Pointdump
The Library erroneously notes the WGS84 Datum as being EPSG:6326. It should be 4326. (There is no 6326 listed in the EPSG site)
Dave Stoll
Las Vegas, Nevada
Message 40 of 57
Pointdump
MAPCSLIBRARY erroneously notes the NAD83 Datum as being EPSG:6269. It should be >>>4269<<<. In the EPSG registry >>>6269<<< refers to the MAGNA-SIRGAS / San Jose del Guaviare urban grid.
Dave Stoll
Las Vegas, Nevada
