AutoCAD Forum
AutoCAD LT 2015 Through VPN server
3 REPLIES 3
434 Views, 3 Replies
I have a question.
can we access AutoCAD LT 2015 in different locations via VPN server?
Thanks.
3 REPLIES 3
filipefrancisco
Access how??? remote, license, other
What are your needs?
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
in reply to: filipefrancisco
Thanks for reply.
Can I access license through VPN server?
TravisNave
Yes.  Accessing the NLM remotely is supported via VPN.  You might have to adjust the FLEXLM_TIMEOUT on the client if there are latency issues though.
Autodesk Forums:
Forma Design Contest
AutoCAD Beta
