Installation & Licensing
Text too small, top of view port print cut off
6 REPLIES 6
703 Views, 6 Replies
Please find attached a screencapture of the display- all faluts are outlined.
Any help would be dearly appericated.
Thanks.
Tags (2)
6 REPLIES 6
TravisNave
What is your screen resolution?
Autodesk Forums:
in reply to: TravisNave
My screen resolution is 1920x1080.
TravisNave
And you didn't modify any default text or Windows settings in Control Panel\All Control Panel Items\Display?
Autodesk Forums:
No, the display was like that when I launched the program for the first time. I tried changing the text size later but that didn't solve anything. Everything is now at its orginal settings. (I'm using windows 8.1 if that makes any difference at all.)
TravisNave
It shouldn't. I run Windows 8.1 on 1600x900.  What is your video card and driver?  There's no doubt you have some strangeness.
Autodesk Forums:
Video cards:
AMD Radeon HD 7560D
AMD Radeon R5 235 + HD 7560 Dual Graphics
Driver:
WDC WD10EZEX-60ZF5A0
Administrator Productivity
