Hi!
I just downloaded and tried to install revit 2012 however i almost imeadiately get the message: Installation complete. Some products failed to install and so nothing is installed. Dont quite know what to do next! Can anyone help me?
Thanks in advance!
Solved by TravisNave. Go to Solution.
Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Uninstall this product from your Control Panel > Programs and try to install your Autodesk product again.
Thank you!!! This was the issue I was dealing with. Uninstalling it got Revit 2012 to install with no problems.
At least the offending versions, I would think. You can always reinstall them after the fact.
Do I uninstall EVERYTHING (with Microsoft Visual C++)? If I do where can i reinstall everything i just uninstalled.
You just need to uninstall the one that is failing. The Autodesk installer will reinstall it for you or you can always get it from Microsoft or Windows Update after.
