Installation & Licensing
Revit 2012 architecture failed to install
7 REPLIES 7
Message 1 of 8
l.g.b.vanderwal
8924 Views, 7 Replies
Hi!
I just downloaded and tried to install revit 2012 however i almost imeadiately get the message: Installation complete. Some products failed to install and so nothing is installed. Dont quite know what to do next! Can anyone help me?
Thanks in advance!
Tags (2)
7 REPLIES 7
Message 2 of 8
Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Uninstall this product from your Control Panel > Programs and try to install your Autodesk product again.
Autodesk Forums:
Message 3 of 8
ALombar4
in reply to: TravisNave
Thank you!!!  This was the issue I was dealing with.  Uninstalling it got Revit 2012 to install with no problems.
Message 4 of 8
in reply to: l.g.b.vanderwal
Need to delete all microsoft visual C++ before re-install the revit architecture?
Message 5 of 8
TravisNave
At least the offending versions, I would think.  You can always reinstall them after the fact.
Autodesk Forums:
Message 6 of 8
Do I uninstall EVERYTHING (with Microsoft Visual C++)?  If I do where can i reinstall everything i just uninstalled.
Message 7 of 8
TravisNave
You just need to uninstall the one that is failing.  The Autodesk installer will reinstall it for you or you can always get it from Microsoft or Windows Update after.
Autodesk Forums:
Message 8 of 8
birsurang
thanks man..
Administrator Productivity
