2014/9/18:16:00:50 Gina Gina === Setup started on Gina by Gina ===
2014/9/18:16:00:50 Gina Gina Path_Length: 148
2014/9/18:16:00:50 Gina Gina Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/18:16:00:50 Gina Gina Launch
2014/9/18:16:00:50 Gina Gina CommandLine /url "
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-... /SN 900-49911107 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/18:16:00:50 Gina Gina Current Directory C:\Users\Gina\AppData\Local\Temp\_AICF8A.tmp
2014/9/18:16:01:43 Gina Gina === Setup ended ===
2014/9/18:16:00:51 Gina Gina === Setup started on Gina by Gina ===
2014/9/18:16:00:51 Gina Gina Path_Length: 148
2014/9/18:16:00:51 Gina Gina Current Directory C:\Users\Gina\AppData\Local\Temp\_AICF8A.tmp
2014/9/18:16:00:51 Gina Gina Launch
2014/9/18:16:01:33 Gina Gina Download Play SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...2014/9/18:16:01:42 Gina Gina Download Complete SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...2014/9/18:16:01:42 Gina Gina PageOpen LaunchDialog
2014/9/18:16:06:40 Gina Gina PageOpen LicenseDialog
2014/9/18:16:06:40 Gina Gina PageOpen ProductInfoDialog
2014/9/18:16:06:40 Gina Gina PageOpen ProductSelectionDialog2
2014/9/18:16:06:45 Gina Gina PageOpen FullProgressDialog
2014/9/18:16:06:46 Gina Gina Download Play VCREDIST2005SP1ATLX86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:07:58 Gina Gina Download Error VCREDIST2005SP1ATLX86 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:18:05 Gina Gina Download User Resume VCREDIST2005SP1ATLX86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:18:36 Gina Gina Download Error VCREDIST2005SP1ATLX86 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:18:47 Gina Gina Download User Resume VCREDIST2005SP1ATLX86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:19:40 Gina Gina Download Error VCREDIST2005SP1ATLX86 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:20:54 Gina Gina Download User Cancel VCREDIST2005SP1ATLX86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:20:54 Gina Gina PageOpen InstallCompleteDialog
2014/9/18:16:21:10 Gina Gina === Setup ended ===
2014/9/18:16:22:11 Gina Gina === Setup started on Gina by Gina ===
2014/9/18:16:22:11 Gina Gina Path_Length: 148
2014/9/18:16:22:11 Gina Gina Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/18:16:22:11 Gina Gina Launch
2014/9/18:16:22:11 Gina Gina CommandLine /url "
2014/9/18:16:22:11 Gina Gina Current Directory C:\Users\Gina\AppData\Local\Temp\_AI5CBA.tmp
2014/9/18:16:22:39 Gina Gina === Setup ended ===
2014/9/18:16:22:39 Gina Gina Download Skipped SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...2014/9/18:16:22:39 Gina Gina PageOpen LaunchDialog
2014/9/18:16:22:49 Gina Gina PageOpen LicenseDialog
2014/9/18:16:22:49 Gina Gina PageOpen ProductInfoDialog
2014/9/18:16:22:49 Gina Gina PageOpen ProductSelectionDialog2
2014/9/18:16:23:20 Gina Gina PageOpen FullProgressDialog
2014/9/18:16:23:22 Gina Gina Download Play VCREDIST2005SP1ATLX86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:23:22 Gina Gina Download Complete VCREDIST2005SP1ATLX86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:23:22 Gina Gina Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Gina\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/9/18:16:23:39 Gina Gina Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/9/18:16:23:39 Gina Gina Download Play VCREDIST2005SP1ATLX64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:23:40 Gina Gina Download Complete VCREDIST2005SP1ATLX64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:23:40 Gina Gina Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Gina\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/9/18:16:23:52 Gina Gina Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/9/18:16:23:52 Gina Gina Download Play VCREDIST2008SP1X86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:23:54 Gina Gina Download Complete VCREDIST2008SP1X86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:23:54 Gina Gina Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/9/18:16:24:06 Gina Gina Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/9/18:16:24:06 Gina Gina Download Play VCREDIST2008SP1X64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:24:08 Gina Gina Download Complete VCREDIST2008SP1X64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:24:08 Gina Gina Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/9/18:16:24:20 Gina Gina Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2014/9/18:16:24:21 Gina Gina Download Play VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:24:24 Gina Gina Download Complete VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:24:24 Gina Gina Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/18:16:24:58 Gina Gina Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/18:16:24:58 Gina Gina Download Play VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:25:00 Gina Gina Download Complete VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:25:00 Gina Gina Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/18:16:25:03 Gina Gina Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/18:16:25:03 Gina Gina Download Play DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...2014/9/18:16:25:05 Gina Gina Download Complete DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...2014/9/18:16:25:05 Gina Gina Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/18:16:25:09 Gina Gina Install DirectX® Runtime Succeeded
2014/9/18:16:25:10 Gina Gina Download Play CM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...2014/9/18:16:25:17 Gina Gina Download Complete CM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...2014/9/18:16:25:17 Gina Gina Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/18:16:25:32 Gina Gina Install Autodesk® Material Library 2015 Succeeded
2014/9/18:16:25:32 Gina Gina Download Play CMILB
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...2014/9/18:16:25:45 Gina Gina Download Complete CMILB
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...2014/9/18:16:25:45 Gina Gina Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/18:16:25:55 Gina Gina Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/18:16:25:55 Gina Gina Download Play CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/9/18:16:28:49 Gina Gina Download Aborted CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/9/18:16:28:49 Gina Gina Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/9/18:16:29:06 Gina Gina Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/18:16:29:26 Gina Gina Rollback Autodesk® Material Library 2015 Succeeded
2014/9/18:16:29:26 Gina Gina Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/18:16:29:26 Gina Gina Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/18:16:29:26 Gina Gina Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/9/18:16:29:26 Gina Gina Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/9/18:16:29:26 Gina Gina Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/9/18:16:29:26 Gina Gina Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/9/18:16:29:26 Gina Gina Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/9/18:16:29:27 Gina Gina PageOpen InstallCompleteDialog
2014/9/18:16:29:46 Gina Gina === Setup ended ===
2014/9/18:16:34:16 Gina Gina === Setup started on Gina by Gina ===
2014/9/18:16:34:16 Gina Gina Path_Length: 148
2014/9/18:16:34:16 Gina Gina Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/18:16:34:16 Gina Gina Launch
2014/9/18:16:34:16 Gina Gina CommandLine /url "
2014/9/18:16:34:16 Gina Gina Current Directory C:\Users\Gina\AppData\Local\Temp\_AI6F52.tmp
2014/9/18:16:35:29 Gina Gina === Setup ended ===
2014/9/18:16:34:18 Gina Gina === Setup started on Gina by Gina ===
2014/9/18:16:34:18 Gina Gina Path_Length: 148
2014/9/18:16:34:18 Gina Gina Current Directory C:\Users\Gina\AppData\Local\Temp\_AI6F52.tmp
2014/9/18:16:34:18 Gina Gina Launch
2014/9/18:16:35:28 Gina Gina Download Skipped SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...2014/9/18:16:35:29 Gina Gina PageOpen LaunchDialog
2014/9/18:16:35:40 Gina Gina PageOpen LicenseDialog
2014/9/18:16:35:40 Gina Gina PageOpen ProductInfoDialog
2014/9/18:16:35:40 Gina Gina PageOpen ProductSelectionDialog2
2014/9/18:16:36:00 Gina Gina PageOpen FullProgressDialog
2014/9/18:16:36:01 Gina Gina Download Skipped VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:36:01 Gina Gina Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/18:16:36:02 Gina Gina Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/18:16:36:03 Gina Gina Download Skipped VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:36:03 Gina Gina Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/18:16:36:03 Gina Gina Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/18:16:36:03 Gina Gina Download Skipped DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...2014/9/18:16:36:03 Gina Gina Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/18:16:36:06 Gina Gina Install DirectX® Runtime Succeeded
2014/9/18:16:36:06 Gina Gina Download Skipped CM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...2014/9/18:16:36:06 Gina Gina Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/18:16:36:19 Gina Gina Install Autodesk® Material Library 2015 Succeeded
2014/9/18:16:36:20 Gina Gina Download Skipped CMILB
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...2014/9/18:16:36:20 Gina Gina Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/18:16:36:30 Gina Gina Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/18:16:36:32 Gina Gina Download Play CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/9/18:16:38:57 Gina Gina Download Aborted CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/9/18:16:38:57 Gina Gina Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/9/18:16:39:08 Gina Gina Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/18:16:39:28 Gina Gina Rollback Autodesk® Material Library 2015 Succeeded
2014/9/18:16:39:28 Gina Gina Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/18:16:39:28 Gina Gina Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/18:16:39:28 Gina Gina Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/9/18:16:39:28 Gina Gina PageOpen InstallCompleteDialog
2014/9/18:16:44:42 Gina Gina === Setup ended ===
2014/9/18:16:46:18 Gina Gina === Setup started on Gina by Gina ===
2014/9/18:16:46:18 Gina Gina Path_Length: 148
2014/9/18:16:46:18 Gina Gina Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/18:16:46:18 Gina Gina Launch
2014/9/18:16:46:18 Gina Gina CommandLine /url "
2014/9/18:16:46:18 Gina Gina Current Directory C:\Users\Gina\AppData\Local\Temp\_AI70C4.tmp
2014/9/18:16:46:46 Gina Gina === Setup ended ===
2014/9/18:16:46:45 Gina Gina Download Skipped SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...2014/9/18:16:46:46 Gina Gina PageOpen LaunchDialog
2014/9/18:16:46:54 Gina Gina PageOpen LicenseDialog
2014/9/18:16:46:54 Gina Gina PageOpen ProductInfoDialog
2014/9/18:16:46:54 Gina Gina PageOpen ProductSelectionDialog2
2014/9/18:16:47:13 Gina Gina PageOpen FullProgressDialog
2014/9/18:16:47:14 Gina Gina Download Skipped VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:47:14 Gina Gina Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/18:16:47:15 Gina Gina Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/18:16:47:15 Gina Gina Download Skipped VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/18:16:47:15 Gina Gina Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/18:16:47:15 Gina Gina Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/18:16:47:15 Gina Gina Download Skipped DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...2014/9/18:16:47:15 Gina Gina Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/18:16:47:18 Gina Gina Install DirectX® Runtime Succeeded
2014/9/18:16:47:18 Gina Gina Download Skipped CM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...2014/9/18:16:47:18 Gina Gina Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/18:16:47:30 Gina Gina Install Autodesk® Material Library 2015 Succeeded
2014/9/18:16:47:31 Gina Gina Download Skipped CMILB
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...2014/9/18:16:47:31 Gina Gina Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/18:16:47:42 Gina Gina Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/18:16:47:43 Gina Gina Download Play CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/9/18:16:49:25 Gina Gina Download Aborted CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/9/18:16:49:25 Gina Gina Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/9/18:16:49:36 Gina Gina Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/18:16:49:55 Gina Gina Rollback Autodesk® Material Library 2015 Succeeded
2014/9/18:16:49:55 Gina Gina Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/18:16:49:56 Gina Gina Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/18:16:49:56 Gina Gina Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/9/18:16:49:56 Gina Gina PageOpen InstallCompleteDialog
2014/9/18:16:52:44 Gina Gina === Setup ended ===
2014/9/19:19:22:46 Gina GINA === Setup started on GINA by Gina ===
2014/9/19:19:22:46 Gina GINA Path_Length: 148
2014/9/19:19:22:46 Gina GINA Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/19:19:22:46 Gina GINA Launch
2014/9/19:19:22:46 Gina GINA CommandLine /url "
2014/9/19:19:22:46 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AIE496.tmp
2014/9/19:19:24:13 Gina GINA === Setup ended ===
2014/9/19:19:22:47 Gina GINA === Setup started on GINA by Gina ===
2014/9/19:19:22:47 Gina GINA Path_Length: 148
2014/9/19:19:22:47 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AIE496.tmp
2014/9/19:19:22:47 Gina GINA Launch
2014/9/19:19:24:12 Gina GINA Download Skipped SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...2014/9/19:19:24:12 Gina GINA PageOpen LaunchDialog
2014/9/19:19:24:32 Gina GINA PageOpen LicenseDialog
2014/9/19:19:24:32 Gina GINA PageOpen ProductInfoDialog
2014/9/19:19:24:32 Gina GINA PageOpen ProductSelectionDialog2
2014/9/19:19:24:42 Gina GINA PageOpen FullProgressDialog
2014/9/19:19:24:43 Gina GINA Download Skipped VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/19:19:24:43 Gina GINA Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/19:19:26:46 Gina GINA Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/19:19:26:46 Gina GINA Download Skipped VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/19:19:26:46 Gina GINA Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/19:19:28:14 Gina GINA Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/19:19:28:14 Gina GINA Download Skipped DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...2014/9/19:19:28:14 Gina GINA Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/19:19:28:29 Gina GINA Install DirectX® Runtime Succeeded
2014/9/19:19:28:29 Gina GINA Download Skipped CM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...2014/9/19:19:28:30 Gina GINA Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/19:19:29:25 Gina GINA Install Autodesk® Material Library 2015 Succeeded
2014/9/19:19:29:26 Gina GINA Download Skipped CMILB
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...2014/9/19:19:29:26 Gina GINA Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/19:19:30:03 Gina GINA Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/19:19:30:05 Gina GINA Download Play CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/9/19:19:31:45 Gina GINA Download Aborted CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/9/19:19:31:45 Gina GINA Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/9/19:19:32:17 Gina GINA Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/19:19:33:18 Gina GINA Rollback Autodesk® Material Library 2015 Succeeded
2014/9/19:19:33:19 Gina GINA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/19:19:33:19 Gina GINA Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/19:19:33:19 Gina GINA Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/9/19:19:33:21 Gina GINA PageOpen InstallCompleteDialog
2014/9/19:19:44:08 Gina GINA === Setup ended ===
2014/9/24:15:41:47 Gina GINA === Setup started on GINA by Gina ===
2014/9/24:15:41:47 Gina GINA Path_Length: 148
2014/9/24:15:41:47 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AID8B2.tmp
2014/9/24:15:41:47 Gina GINA Launch
2014/9/24:15:41:49 Gina GINA === Setup ended ===
2014/9/24:15:41:45 Gina GINA === Setup started on GINA by Gina ===
2014/9/24:15:41:45 Gina GINA Path_Length: 148
2014/9/24:15:41:45 Gina GINA Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/24:15:41:45 Gina GINA Launch
2014/9/24:15:41:45 Gina GINA CommandLine
2014/9/24:15:41:45 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AID8B2.tmp
2014/9/24:15:41:51 Gina GINA === Setup ended ===
2014/9/24:15:43:50 Gina GINA === Setup started on GINA by Gina ===
2014/9/24:15:43:50 Gina GINA Path_Length: 148
2014/9/24:15:43:50 Gina GINA Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/24:15:43:50 Gina GINA Launch
2014/9/24:15:43:50 Gina GINA CommandLine /url "
2014/9/24:15:43:50 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AIC196.tmp
2014/9/24:15:43:52 Gina GINA === Setup ended ===
2014/9/24:15:43:51 Gina GINA === Setup started on GINA by Gina ===
2014/9/24:15:43:51 Gina GINA Path_Length: 148
2014/9/24:15:43:51 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AIC196.tmp
2014/9/24:15:43:51 Gina GINA Launch
2014/9/24:15:43:51 Gina GINA Download Skipped SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...2014/9/24:15:43:52 Gina GINA PageOpen LaunchDialog
2014/9/24:15:44:00 Gina GINA PageOpen LicenseDialog
2014/9/24:15:44:00 Gina GINA PageOpen ProductInfoDialog
2014/9/24:15:44:00 Gina GINA PageOpen ProductSelectionDialog2
2014/9/24:15:44:37 Gina GINA PageOpen FullProgressDialog
2014/9/24:15:44:37 Gina GINA Download Skipped VCREDIST2005SP1ATLX86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/24:15:44:38 Gina GINA Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Gina\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/9/24:15:44:43 Gina GINA Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/9/24:15:44:43 Gina GINA Download Skipped VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/24:15:44:43 Gina GINA Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/24:15:45:25 Gina GINA Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/24:15:45:25 Gina GINA Download Skipped VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/24:15:45:25 Gina GINA Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/24:15:45:51 Gina GINA Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/24:15:45:52 Gina GINA Download Skipped DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...2014/9/24:15:45:52 Gina GINA Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/24:15:45:57 Gina GINA Install DirectX® Runtime Succeeded
2014/9/24:15:45:57 Gina GINA Download Skipped CM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...2014/9/24:15:45:58 Gina GINA Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/24:15:46:22 Gina GINA Install Autodesk® Material Library 2015 Succeeded
2014/9/24:15:46:22 Gina GINA Download Skipped CMILB
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...2014/9/24:15:46:22 Gina GINA Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/24:15:46:33 Gina GINA Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/24:15:46:34 Gina GINA Download Play CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/9/24:15:49:34 Gina GINA Download Aborted CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/9/24:15:49:34 Gina GINA Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/9/24:15:49:46 Gina GINA Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/24:15:50:02 Gina GINA Rollback Autodesk® Material Library 2015 Succeeded
2014/9/24:15:50:02 Gina GINA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/24:15:50:02 Gina GINA Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/24:15:50:02 Gina GINA Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/9/24:15:50:02 Gina GINA Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/9/24:15:50:03 Gina GINA PageOpen InstallCompleteDialog
2014/9/24:15:50:20 Gina GINA === Setup ended ===
2014/9/24:15:50:54 Gina GINA === Setup started on GINA by Gina ===
2014/9/24:15:50:54 Gina GINA Path_Length: 148
2014/9/24:15:50:54 Gina GINA Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/24:15:50:54 Gina GINA Launch
2014/9/24:15:50:54 Gina GINA CommandLine /url "
2014/9/24:15:50:54 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AI37C3.tmp
2014/9/24:15:50:56 Gina GINA === Setup ended ===
2014/9/24:15:50:55 Gina GINA Download Skipped SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...2014/9/24:15:50:55 Gina GINA PageOpen LaunchDialog
2014/9/24:15:51:00 Gina GINA PageOpen LicenseDialog
2014/9/24:15:51:00 Gina GINA PageOpen ProductInfoDialog
2014/9/24:15:51:00 Gina GINA PageOpen ProductSelectionDialog2
2014/9/24:15:51:03 Gina GINA PageOpen FullProgressDialog
2014/9/24:15:51:04 Gina GINA Download Skipped VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/24:15:51:04 Gina GINA Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/24:15:51:05 Gina GINA Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/24:15:51:05 Gina GINA Download Skipped VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...2014/9/24:15:51:05 Gina GINA Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/24:15:51:05 Gina GINA Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/24:15:51:05 Gina GINA Download Skipped DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...2014/9/24:15:51:05 Gina GINA Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/24:15:51:10 Gina GINA Install DirectX® Runtime Succeeded
2014/9/24:15:51:10 Gina GINA Download Skipped CM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...2014/9/24:15:51:10 Gina GINA Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/24:15:51:26 Gina GINA Install Autodesk® Material Library 2015 Succeeded
2014/9/24:15:51:26 Gina GINA Download Skipped CMILB
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...2014/9/24:15:51:27 Gina GINA Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/24:15:51:41 Gina GINA Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/24:15:51:41 Gina GINA Download Play CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/9/24:15:54:18 Gina GINA Download Aborted CMILM
http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...2014/9/24:15:54:18 Gina GINA Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/9/24:15:54:28 Gina GINA Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/24:15:54:44 Gina GINA Rollback Autodesk® Material Library 2015 Succeeded
2014/9/24:15:54:44 Gina GINA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/24:15:54:44 Gina GINA Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/24:15:54:44 Gina GINA Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
