Installation & Licensing
Products unable to install
6 REPLIES 6
Gina.Isaia
586 Views, 6 Replies
Hi guys,
I recently bought a new laptop, and tried to install 3DS Max onto this one. Since it didn't work on my previous one, I didn't even think it would work on this one. Apparantly, the installation was succesfull, but "some products" failed to install (which basically means almost all of them). I looked up any solution for the error (1619 and/or 1603) but only found one that leads to a dead page. Is there anything you know about this and maybe can help me out here?
I've tried running it as administrator and have uninstalled / reinstalled the whole thing about three times. I get the same error everytime.
This is the entire installation log file:
Spoiler
2014/9/18:16:00:50 Gina Gina === Setup started on Gina by Gina ===
2014/9/18:16:00:50 Gina Gina Path_Length: 148
2014/9/18:16:00:50 Gina Gina Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/18:16:00:50 Gina Gina Launch
2014/9/18:16:00:50 Gina Gina CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-... /SN 900-49911107 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/18:16:00:50 Gina Gina Current Directory C:\Users\Gina\AppData\Local\Temp\_AICF8A.tmp
2014/9/18:16:01:43 Gina Gina === Setup ended ===
2014/9/18:16:00:51 Gina Gina === Setup started on Gina by Gina ===
2014/9/18:16:00:51 Gina Gina Path_Length: 148
2014/9/18:16:00:51 Gina Gina Current Directory C:\Users\Gina\AppData\Local\Temp\_AICF8A.tmp
2014/9/18:16:00:51 Gina Gina Launch
2014/9/18:16:01:33 Gina Gina Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...
2014/9/18:16:01:42 Gina Gina Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...
2014/9/18:16:01:42 Gina Gina PageOpen LaunchDialog
2014/9/18:16:06:40 Gina Gina PageOpen LicenseDialog
2014/9/18:16:06:40 Gina Gina PageOpen ProductInfoDialog
2014/9/18:16:06:40 Gina Gina PageOpen ProductSelectionDialog2
2014/9/18:16:06:45 Gina Gina PageOpen FullProgressDialog
2014/9/18:16:06:46 Gina Gina Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:07:58 Gina Gina Download Error VCREDIST2005SP1ATLX86 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:18:05 Gina Gina Download User Resume VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:18:36 Gina Gina Download Error VCREDIST2005SP1ATLX86 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:18:47 Gina Gina Download User Resume VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:19:40 Gina Gina Download Error VCREDIST2005SP1ATLX86 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:20:54 Gina Gina Download User Cancel VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:20:54 Gina Gina PageOpen InstallCompleteDialog
2014/9/18:16:21:10 Gina Gina === Setup ended ===
2014/9/18:16:22:11 Gina Gina === Setup started on Gina by Gina ===
2014/9/18:16:22:11 Gina Gina Path_Length: 148
2014/9/18:16:22:11 Gina Gina Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/18:16:22:11 Gina Gina Launch
2014/9/18:16:22:11 Gina Gina CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-... /SN 900-49911107 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/18:16:22:11 Gina Gina Current Directory C:\Users\Gina\AppData\Local\Temp\_AI5CBA.tmp
2014/9/18:16:22:39 Gina Gina === Setup ended ===
2014/9/18:16:22:39 Gina Gina Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...
2014/9/18:16:22:39 Gina Gina PageOpen LaunchDialog
2014/9/18:16:22:49 Gina Gina PageOpen LicenseDialog
2014/9/18:16:22:49 Gina Gina PageOpen ProductInfoDialog
2014/9/18:16:22:49 Gina Gina PageOpen ProductSelectionDialog2
2014/9/18:16:23:20 Gina Gina PageOpen FullProgressDialog
2014/9/18:16:23:22 Gina Gina Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:23:22 Gina Gina Download Complete VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:23:22 Gina Gina Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Gina\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/9/18:16:23:39 Gina Gina Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/9/18:16:23:39 Gina Gina Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:23:40 Gina Gina Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:23:40 Gina Gina Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Gina\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/9/18:16:23:52 Gina Gina Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/9/18:16:23:52 Gina Gina Download Play VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:23:54 Gina Gina Download Complete VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:23:54 Gina Gina Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/9/18:16:24:06 Gina Gina Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/9/18:16:24:06 Gina Gina Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:24:08 Gina Gina Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:24:08 Gina Gina Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/9/18:16:24:20 Gina Gina Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2014/9/18:16:24:21 Gina Gina Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:24:24 Gina Gina Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:24:24 Gina Gina Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/18:16:24:58 Gina Gina Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/18:16:24:58 Gina Gina Download Play VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:25:00 Gina Gina Download Complete VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:25:00 Gina Gina Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/18:16:25:03 Gina Gina Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/18:16:25:03 Gina Gina Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...
2014/9/18:16:25:05 Gina Gina Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...
2014/9/18:16:25:05 Gina Gina Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/18:16:25:09 Gina Gina Install DirectX® Runtime Succeeded
2014/9/18:16:25:10 Gina Gina Download Play CM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...
2014/9/18:16:25:17 Gina Gina Download Complete CM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...
2014/9/18:16:25:17 Gina Gina Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/18:16:25:32 Gina Gina Install Autodesk® Material Library 2015 Succeeded
2014/9/18:16:25:32 Gina Gina Download Play CMILB http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...
2014/9/18:16:25:45 Gina Gina Download Complete CMILB http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...
2014/9/18:16:25:45 Gina Gina Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/18:16:25:55 Gina Gina Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/18:16:25:55 Gina Gina Download Play CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...
2014/9/18:16:28:49 Gina Gina Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...
2014/9/18:16:28:49 Gina Gina Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/9/18:16:29:06 Gina Gina Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/18:16:29:26 Gina Gina Rollback Autodesk® Material Library 2015 Succeeded
2014/9/18:16:29:26 Gina Gina Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/18:16:29:26 Gina Gina Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/18:16:29:26 Gina Gina Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/9/18:16:29:26 Gina Gina Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/9/18:16:29:26 Gina Gina Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/9/18:16:29:26 Gina Gina Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/9/18:16:29:26 Gina Gina Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/9/18:16:29:27 Gina Gina PageOpen InstallCompleteDialog
2014/9/18:16:29:46 Gina Gina === Setup ended ===
2014/9/18:16:34:16 Gina Gina === Setup started on Gina by Gina ===
2014/9/18:16:34:16 Gina Gina Path_Length: 148
2014/9/18:16:34:16 Gina Gina Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/18:16:34:16 Gina Gina Launch
2014/9/18:16:34:16 Gina Gina CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-... /SN 900-49911107 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/18:16:34:16 Gina Gina Current Directory C:\Users\Gina\AppData\Local\Temp\_AI6F52.tmp
2014/9/18:16:35:29 Gina Gina === Setup ended ===
2014/9/18:16:34:18 Gina Gina === Setup started on Gina by Gina ===
2014/9/18:16:34:18 Gina Gina Path_Length: 148
2014/9/18:16:34:18 Gina Gina Current Directory C:\Users\Gina\AppData\Local\Temp\_AI6F52.tmp
2014/9/18:16:34:18 Gina Gina Launch
2014/9/18:16:35:28 Gina Gina Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...
2014/9/18:16:35:29 Gina Gina PageOpen LaunchDialog
2014/9/18:16:35:40 Gina Gina PageOpen LicenseDialog
2014/9/18:16:35:40 Gina Gina PageOpen ProductInfoDialog
2014/9/18:16:35:40 Gina Gina PageOpen ProductSelectionDialog2
2014/9/18:16:36:00 Gina Gina PageOpen FullProgressDialog
2014/9/18:16:36:01 Gina Gina Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:36:01 Gina Gina Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/18:16:36:02 Gina Gina Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/18:16:36:03 Gina Gina Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:36:03 Gina Gina Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/18:16:36:03 Gina Gina Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/18:16:36:03 Gina Gina Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...
2014/9/18:16:36:03 Gina Gina Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/18:16:36:06 Gina Gina Install DirectX® Runtime Succeeded
2014/9/18:16:36:06 Gina Gina Download Skipped CM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...
2014/9/18:16:36:06 Gina Gina Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/18:16:36:19 Gina Gina Install Autodesk® Material Library 2015 Succeeded
2014/9/18:16:36:20 Gina Gina Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...
2014/9/18:16:36:20 Gina Gina Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/18:16:36:30 Gina Gina Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/18:16:36:32 Gina Gina Download Play CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...
2014/9/18:16:38:57 Gina Gina Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...
2014/9/18:16:38:57 Gina Gina Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/9/18:16:39:08 Gina Gina Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/18:16:39:28 Gina Gina Rollback Autodesk® Material Library 2015 Succeeded
2014/9/18:16:39:28 Gina Gina Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/18:16:39:28 Gina Gina Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/18:16:39:28 Gina Gina Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/9/18:16:39:28 Gina Gina PageOpen InstallCompleteDialog
2014/9/18:16:44:42 Gina Gina === Setup ended ===
2014/9/18:16:46:18 Gina Gina === Setup started on Gina by Gina ===
2014/9/18:16:46:18 Gina Gina Path_Length: 148
2014/9/18:16:46:18 Gina Gina Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/18:16:46:18 Gina Gina Launch
2014/9/18:16:46:18 Gina Gina CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-... /SN 900-49911107 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/18:16:46:18 Gina Gina Current Directory C:\Users\Gina\AppData\Local\Temp\_AI70C4.tmp
2014/9/18:16:46:46 Gina Gina === Setup ended ===
2014/9/18:16:46:45 Gina Gina Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...
2014/9/18:16:46:46 Gina Gina PageOpen LaunchDialog
2014/9/18:16:46:54 Gina Gina PageOpen LicenseDialog
2014/9/18:16:46:54 Gina Gina PageOpen ProductInfoDialog
2014/9/18:16:46:54 Gina Gina PageOpen ProductSelectionDialog2
2014/9/18:16:47:13 Gina Gina PageOpen FullProgressDialog
2014/9/18:16:47:14 Gina Gina Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:47:14 Gina Gina Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/18:16:47:15 Gina Gina Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/18:16:47:15 Gina Gina Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/18:16:47:15 Gina Gina Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/18:16:47:15 Gina Gina Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/18:16:47:15 Gina Gina Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...
2014/9/18:16:47:15 Gina Gina Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/18:16:47:18 Gina Gina Install DirectX® Runtime Succeeded
2014/9/18:16:47:18 Gina Gina Download Skipped CM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...
2014/9/18:16:47:18 Gina Gina Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/18:16:47:30 Gina Gina Install Autodesk® Material Library 2015 Succeeded
2014/9/18:16:47:31 Gina Gina Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...
2014/9/18:16:47:31 Gina Gina Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/18:16:47:42 Gina Gina Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/18:16:47:43 Gina Gina Download Play CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...
2014/9/18:16:49:25 Gina Gina Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...
2014/9/18:16:49:25 Gina Gina Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/9/18:16:49:36 Gina Gina Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/18:16:49:55 Gina Gina Rollback Autodesk® Material Library 2015 Succeeded
2014/9/18:16:49:55 Gina Gina Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/18:16:49:56 Gina Gina Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/18:16:49:56 Gina Gina Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/9/18:16:49:56 Gina Gina PageOpen InstallCompleteDialog
2014/9/18:16:52:44 Gina Gina === Setup ended ===
2014/9/19:19:22:46 Gina GINA === Setup started on GINA by Gina ===
2014/9/19:19:22:46 Gina GINA Path_Length: 148
2014/9/19:19:22:46 Gina GINA Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/19:19:22:46 Gina GINA Launch
2014/9/19:19:22:46 Gina GINA CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-... /SN 900-49911107 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/19:19:22:46 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AIE496.tmp
2014/9/19:19:24:13 Gina GINA === Setup ended ===
2014/9/19:19:22:47 Gina GINA === Setup started on GINA by Gina ===
2014/9/19:19:22:47 Gina GINA Path_Length: 148
2014/9/19:19:22:47 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AIE496.tmp
2014/9/19:19:22:47 Gina GINA Launch
2014/9/19:19:24:12 Gina GINA Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...
2014/9/19:19:24:12 Gina GINA PageOpen LaunchDialog
2014/9/19:19:24:32 Gina GINA PageOpen LicenseDialog
2014/9/19:19:24:32 Gina GINA PageOpen ProductInfoDialog
2014/9/19:19:24:32 Gina GINA PageOpen ProductSelectionDialog2
2014/9/19:19:24:42 Gina GINA PageOpen FullProgressDialog
2014/9/19:19:24:43 Gina GINA Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/19:19:24:43 Gina GINA Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/19:19:26:46 Gina GINA Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/19:19:26:46 Gina GINA Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/19:19:26:46 Gina GINA Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/19:19:28:14 Gina GINA Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/19:19:28:14 Gina GINA Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...
2014/9/19:19:28:14 Gina GINA Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/19:19:28:29 Gina GINA Install DirectX® Runtime Succeeded
2014/9/19:19:28:29 Gina GINA Download Skipped CM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...
2014/9/19:19:28:30 Gina GINA Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/19:19:29:25 Gina GINA Install Autodesk® Material Library 2015 Succeeded
2014/9/19:19:29:26 Gina GINA Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...
2014/9/19:19:29:26 Gina GINA Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/19:19:30:03 Gina GINA Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/19:19:30:05 Gina GINA Download Play CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...
2014/9/19:19:31:45 Gina GINA Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...
2014/9/19:19:31:45 Gina GINA Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/9/19:19:32:17 Gina GINA Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/19:19:33:18 Gina GINA Rollback Autodesk® Material Library 2015 Succeeded
2014/9/19:19:33:19 Gina GINA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/19:19:33:19 Gina GINA Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/19:19:33:19 Gina GINA Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/9/19:19:33:21 Gina GINA PageOpen InstallCompleteDialog
2014/9/19:19:44:08 Gina GINA === Setup ended ===
2014/9/24:15:41:47 Gina GINA === Setup started on GINA by Gina ===
2014/9/24:15:41:47 Gina GINA Path_Length: 148
2014/9/24:15:41:47 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AID8B2.tmp
2014/9/24:15:41:47 Gina GINA Launch
2014/9/24:15:41:49 Gina GINA === Setup ended ===
2014/9/24:15:41:45 Gina GINA === Setup started on GINA by Gina ===
2014/9/24:15:41:45 Gina GINA Path_Length: 148
2014/9/24:15:41:45 Gina GINA Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/24:15:41:45 Gina GINA Launch
2014/9/24:15:41:45 Gina GINA CommandLine
2014/9/24:15:41:45 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AID8B2.tmp
2014/9/24:15:41:51 Gina GINA === Setup ended ===
2014/9/24:15:43:50 Gina GINA === Setup started on GINA by Gina ===
2014/9/24:15:43:50 Gina GINA Path_Length: 148
2014/9/24:15:43:50 Gina GINA Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/24:15:43:50 Gina GINA Launch
2014/9/24:15:43:50 Gina GINA CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-... /SN 900-49911107 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/24:15:43:50 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AIC196.tmp
2014/9/24:15:43:52 Gina GINA === Setup ended ===
2014/9/24:15:43:51 Gina GINA === Setup started on GINA by Gina ===
2014/9/24:15:43:51 Gina GINA Path_Length: 148
2014/9/24:15:43:51 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AIC196.tmp
2014/9/24:15:43:51 Gina GINA Launch
2014/9/24:15:43:51 Gina GINA Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...
2014/9/24:15:43:52 Gina GINA PageOpen LaunchDialog
2014/9/24:15:44:00 Gina GINA PageOpen LicenseDialog
2014/9/24:15:44:00 Gina GINA PageOpen ProductInfoDialog
2014/9/24:15:44:00 Gina GINA PageOpen ProductSelectionDialog2
2014/9/24:15:44:37 Gina GINA PageOpen FullProgressDialog
2014/9/24:15:44:37 Gina GINA Download Skipped VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/24:15:44:38 Gina GINA Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Gina\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/9/24:15:44:43 Gina GINA Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/9/24:15:44:43 Gina GINA Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/24:15:44:43 Gina GINA Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/24:15:45:25 Gina GINA Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/24:15:45:25 Gina GINA Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/24:15:45:25 Gina GINA Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/24:15:45:51 Gina GINA Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/24:15:45:52 Gina GINA Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...
2014/9/24:15:45:52 Gina GINA Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/24:15:45:57 Gina GINA Install DirectX® Runtime Succeeded
2014/9/24:15:45:57 Gina GINA Download Skipped CM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...
2014/9/24:15:45:58 Gina GINA Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/24:15:46:22 Gina GINA Install Autodesk® Material Library 2015 Succeeded
2014/9/24:15:46:22 Gina GINA Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...
2014/9/24:15:46:22 Gina GINA Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/24:15:46:33 Gina GINA Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/24:15:46:34 Gina GINA Download Play CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...
2014/9/24:15:49:34 Gina GINA Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...
2014/9/24:15:49:34 Gina GINA Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/9/24:15:49:46 Gina GINA Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/24:15:50:02 Gina GINA Rollback Autodesk® Material Library 2015 Succeeded
2014/9/24:15:50:02 Gina GINA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/24:15:50:02 Gina GINA Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/24:15:50:02 Gina GINA Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/9/24:15:50:02 Gina GINA Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/9/24:15:50:03 Gina GINA PageOpen InstallCompleteDialog
2014/9/24:15:50:20 Gina GINA === Setup ended ===
2014/9/24:15:50:54 Gina GINA === Setup started on GINA by Gina ===
2014/9/24:15:50:54 Gina GINA Path_Length: 148
2014/9/24:15:50:54 Gina GINA Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/9/24:15:50:54 Gina GINA Launch
2014/9/24:15:50:54 Gina GINA CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-... /SN 900-49911107 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/24:15:50:54 Gina GINA Current Directory C:\Users\Gina\AppData\Local\Temp\_AI37C3.tmp
2014/9/24:15:50:56 Gina GINA === Setup ended ===
2014/9/24:15:50:55 Gina GINA Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x64...
2014/9/24:15:50:55 Gina GINA PageOpen LaunchDialog
2014/9/24:15:51:00 Gina GINA PageOpen LicenseDialog
2014/9/24:15:51:00 Gina GINA PageOpen ProductInfoDialog
2014/9/24:15:51:00 Gina GINA PageOpen ProductSelectionDialog2
2014/9/24:15:51:03 Gina GINA PageOpen FullProgressDialog
2014/9/24:15:51:04 Gina GINA Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/24:15:51:04 Gina GINA Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/24:15:51:05 Gina GINA Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/24:15:51:05 Gina GINA Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIST2...
2014/9/24:15:51:05 Gina GINA Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/24:15:51:05 Gina GINA Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/24:15:51:05 Gina GINA Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX.t...
2014/9/24:15:51:05 Gina GINA Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/24:15:51:10 Gina GINA Install DirectX® Runtime Succeeded
2014/9/24:15:51:10 Gina GINA Download Skipped CM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar.lz...
2014/9/24:15:51:10 Gina GINA Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/24:15:51:26 Gina GINA Install Autodesk® Material Library 2015 Succeeded
2014/9/24:15:51:26 Gina GINA Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.tar...
2014/9/24:15:51:27 Gina GINA Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/24:15:51:41 Gina GINA Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/24:15:51:41 Gina GINA Download Play CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...
2014/9/24:15:54:18 Gina GINA Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.tar...
2014/9/24:15:54:18 Gina GINA Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/9/24:15:54:28 Gina GINA Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/9/24:15:54:44 Gina GINA Rollback Autodesk® Material Library 2015 Succeeded
2014/9/24:15:54:44 Gina GINA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/9/24:15:54:44 Gina GINA Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/24:15:54:44 Gina GINA Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
6 REPLIES 6
TravisNave
in reply to: Gina.Isaia
Bonus points for putting the log in the spoiler.  Smiley Very Happy
Your failure is listed here:
 I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Good Luck!
Autodesk Forums:
ukdxb012
in reply to: TravisNave
Try downloading the Material Library from here as a direct download... http://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Hopefully this will allow you to complete the install, if not, please upload a new log to identify what might now be a new issue.
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Gina.Isaia
@TravisNave,
I have tried this, but at this very moment (after downloading via the virtual assistant and double clicking it) I get an error saying "File Corrupted Error".  I tried making a map on my desktop to download the product to, but this was actually kind of difficult. My laptop somehow doesn't give me an option to place the download file where I want it to be.
Do you think this has anything to do with the error I get now?
TravisNave
Well, you could try the trial.  You should probably download with your antivirus temporarily disabled.  It has been known to corrupt large downloads.
Also, the Materials Library download provided by my fellow Expert Elite member is a good resource -- since that is where your failure exists.
Autodesk Forums:
Gina.Isaia
in reply to: ukdxb012
@DuncanBrannan82
I have downloaded the Autodesk Medium Resolution Materials Image Library 2015 from the link you gave me. I opened the file and it shows me MediumImageLibrary2015.msi and Common~1.cab.
The thing is, when I double click the MediumImageLibrary, it gives me an error. It says "Texture libraries cannot be installed before the material library. Please run the installer, "MaterialLibrary2015.msi, then try to install the texture libraries again". But I thought what I downloaded was the Material Library?
There are no other files in the zipfile, other than the ones I wrote about.
Gina.Isaia
TravisNave,
Since the other guy isn't responding, could you please look into my previous message? I really need to get it working for school, as I'm falling behind now.
Administrator Productivity
