Installation & Licensing
406 Views, 4 Replies
Problem with LMTOOLS
The Problem is free licenses not return to server. Any ideas?
4 REPLIES 4
hi,
Create an file adskflex.opt.
Type "timeout 900" in it.
"Reread licence file" in start/stop/reread.
Franck Hervet
www.aricad.fr
a écrit dans le message de news:
5354817@discussion.autodesk.com...
Franck Hervet said the following On 10/9/2006 6:24 AM:
> hi,
...and put it in the same directory as the license file.
...or whatever value in seconds that you feel is appropriate.
R.K. McSwain
http://rkmcswain.blogspot.com
TravisNave
If the license isn't free after the program is closed, check the following:
acad.exe has successfully exited from the Processes tab of Task Manager. If acad.exe (or inventor.exe, etc.) is still running, the license will not be freed.
Also check to make sure that the license isn't being borrowed for some strange reason.
Otherwise, if the free licenses aren't returning as a result of just being idle, then yes, that adskflex.opt options file works like a charm.
Autodesk Forums:
Thanks we will try.
Administrator Productivity
