Installation & Licensing
Liscensing Windows Shows Up Black - Inventor 2012
3 REPLIES 3
1010 Views, 3 Replies
I have recently installed inventor 2012 on my Windows 7 64-bit computer. When the installer askes for the serial number and product code and stuff, everything is fine. But when i start up inventor it loads fine then it shows me a screen saying do you want to active now or try as a trail? I click activite but this is the screen i get:
(Look at attachment)
What should i do? Thank you for any help...
Andrew
3 REPLIES 3
It's very possible that your system may have insufficient resources graphics wise. Can you post your system info as listed here?
http://teknigroup.com/support/Inventor/Howto.html
In addition, you do need to install Inventor using this information:
If you need to reinstall, go here for the Clean Uninstall information:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13187758&linkID=9242018
Here are my computer specs(note when i press try and use invetor it runs somthly so  i dont think it is the graphics card.):
  • Windows 7 Home Premium 64-bit
  • Autodesk Inventor 2012
  • Mobile Intel 4 Series express Chipset Family
  • Intel(R) Core(TM)2 Duo CPU T6600 @ 2.20 GHz
  • RAM: 4GB
  • Running McAffe
TravisNave
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
Autodesk Forums:
Administrator Productivity
