Installation & Licensing
Liscensing Windows Shows Up Black - Inventor 2012
3 REPLIES 3
ayoungprogrammer
913 Views, 3 Replies
I have recently installed inventor 2012 on my Windows 7 64-bit computer. When the installer askes for the serial number and product code and stuff, everything is fine. But when i start up inventor it loads fine then it shows me a screen saying do you want to active now or try as a trail? I click activite but this is the screen i get:
(Look at attachment)
What should i do? Thank you for any help...
Andrew
3 REPLIES 3
It's very possible that your system may have insufficient resources graphics wise. Can you post your system info as listed here?
http://teknigroup.com/support/Inventor/Howto.html
In addition, you do need to install Inventor using this information:
If you need to reinstall, go here for the Clean Uninstall information:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13187758&linkID=9242018
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Here are my computer specs(note when i press try and use invetor it runs somthly so  i dont think it is the graphics card.):
  • Windows 7 Home Premium 64-bit
  • Autodesk Inventor 2012
  • Mobile Intel 4 Series express Chipset Family
  • Intel(R) Core(TM)2 Duo CPU T6600 @ 2.20 GHz
  • RAM: 4GB
  • Running McAffe
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
Autodesk Forums:
Administrator Productivity
