Installation & Licensing
License error [-158.61003.2]
4 REPLIES 4
t_gawlik
1214 Views, 4 Replies
Some new license error. PrDSS on Win 8.1. I know that the OS is not supported by Autodesk but my customer made a mistake.
Best Regards
Tomasz Gawlik
Tags (1)
4 REPLIES 4
TravisNave
in reply to: t_gawlik
Error -158 indicates a problem with Trusted Storage.  Autodesk licensing does not use this feature, so it is odd that you would ever get it.  If this is a network licensed version, it should work with Windows 8.1.
Autodesk Forums:
t_gawlik
in reply to: TravisNave
1. Customer mistake: He has WIN 7 - None Win 8…
2. Standalone license
2. Yesterday He has installed SP for PrDSS and Inventor launched, but Mechanical dont. After register software, Mechanical runing and works correctly.
That problem is solved now.
best regards
Tomasz Gawlik
TravisNave
Have you installed the latest service pack?
Autodesk Forums:
t_gawlik
AutoCAD Mechanical 2014 z dodatkiem Service Pack 1
Probably this one: ACM2014SP1_64bit.exe (exe - 43921 Kb)
Administrator Productivity
