Installation & Licensing
Help! "Corupt file" message when installing AutoCAD 2011
1 REPLY 1
317 Views, 1 Reply
I needed to download AutoCAD 2011 because my 2010 student version had expired. I removed the 2010 version and tried a couple of times to download 2011 but it doesn't complete installation because an error message pops up saying "corrupt files, cannot continue", or something like that. I could download AutoCAD Architecture or others but would prefer the standard. Can anyone help me?! Thanks, Amy
1 REPLY 1
TravisNave
You'll probably have to redownload the program.  Make sure to disable virus scan checking and use the alternate download method if you still have problems.  Alternately, you may be able to obtain trial media from a reseller in your area.
Autodesk Forums:
Administrator Productivity
