Installation & Licensing
Support through subscription portal problem
3 REPLIES 3
357 Views, 3 Replies
I cannot send a support request through subscription becase the button for "Severity" is blank. You can select the block, but the entries are empty. So I get the message that this is a required field. What to do?
Tim
3 REPLIES 3
TravisNave
Oops.  You might make a request here to let them know:
http://usa.autodesk.com/adsk/servlet/item?id=12338355&siteID=123112
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
philip.s
Hi TimSR,
Did you make sure to select a product (using the little magnifying glass) and then topic first? Have you tried in a different web browser?
in reply to: philip.s
Thanks for the help. I contacted Customer Support and the culprit turned out to be Internet Explorer 9. They said this problem is occurring in IE 9 and Google Chrome. I needed to use Firefox or IE8. I downgraded to IE 8 and that fixed it.
Thanks!
Tim
Administrator Productivity
