Installation & Licensing
First run initializing - Autocad LT 2012
6 REPLIES 6
2194 Views, 6 Replies
We have 15 computers working with Autocad LT 2012, all of them are working fine, exept one.
All computers have the same configuration (CPU, memory....), and using Windows 7 Pro 64 bit
On the computer with problem. each time when we start AutoCAD LT 2012, The startup banner comes up and does the "First Run Initialization" and it takes a long (long long) time to start, and it works fine after the startup is done.
We called the Autodesk phone support, and they told us to put a message here and we are supposed to have a response from the Autodesk support technicians.
6 REPLIES 6
pendean
I think they meant this forum instead:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
However, might I suggest that on the problem machine you simply create a new Windows Profile for the user and then try using LT: I suspect the problem will go away.
TravisNave
I agree with Dean. Try creating another profile with local admin rights and see if the issue is resolved in the new login.  If so, just rebuild the problematic Windows profile.
Autodesk Forums:
in reply to: TravisNave
Thank you Pendean and TravisNave for your responses.
The computer with problem is a network computer, and users have not a reserved machine for each of them, it means they can use any machine.
On this computer, any user who logs on, encounters this problem, either a local or domain user, an administrator or a standard user, a new account or existing account! everyone has this problem.
I made another test with a new local administrator account freshly created, but it's still the same problem.
Before I forget, the computer has been formatted and reinstalled from scratch, and Autocad LT 2012 installation was made several times with different CDs and different licence keys!
Any other suggestion?
thank you,
TravisNave
Typically, roaming profiles is not supported.  To resolve this, you may have to launch the profile as a local profile, and ensure the product launches successfully.  At that point, returning to roaming may work.
Autodesk Forums:
Thank you for the fast response.
We do not use roaming profiles, all our users use local profiles, and they do not save anything localy (on the computer), that is why they can use any machine without any problem.
Thanks.
TravisNave
Ahhh.  I see.  Well in that case, sounds like you have a problematic computer.  If they are all the same, you might consider just re-imaging the machine and starting fresh.
Autodesk Forums:
Administrator Productivity
