Trouble installing Revit 2016 to my windows-7 ultimate
please help me
lawrence
rudi.roux
Hi @Anonymous
Welcome to the Community! Smiley Happy
OPTION ONE:
Ok, so the first thing you could try is to download straight from VIRTUAL AGENT.
After Downloading, follow these steps:
You should clean your TEMP Folder prior to installation:
  • On the Windows Start menu, enter %TEMP% in the "Search programs and files" edit field. (Windows Start Button Search)
  • In the Temp folder, press CTRL+A to select all the files and folders contained in the Temp directory and delete them.
  • Make sure that you put the source installation files to be extracted/setup files in your root drive e.g. - C:\ (By default)
  • Windows sometimes cannot manage to install some components like vcredist or ADSK material library once trying to install from other root drives.
  • Make sure that run everything as administrator or with administrative rights. To be sure that you are, right-click and select the "Run as Administrator".
OPTION TWO: (If you still struggle to Install, then do the following)
Let's start fresh with a to CLEAN UNINSTALL AutoCAD and then also remove .NET and C++ libraries and then reinstall them again followed by reinstalling AutoCAD.
Steps to follow: (BREAKDOWN of OPTION TWO)
Clean uninstall AutoCAD >> Remove .NET & C ++  and re-install >> Copy Downloaded Installation Files from Virtual Agent to correct main drive root (C:\) >> Run Extraction/Setup as Admin.
Some of my other post which resolved installation issues:
POST ONE
POST TWO
I hope this will resolve your issues! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Alexander.Rivilis
Please ask this question in appropriate forum:  Installation & Licensing
Also provide log-file (underlined on your screenshot) for diagnostics (remove all confidential information, such as Serial Number, e-mail, etc.).
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
TravisNave
Without the log file it is hard to tell.  It is either likely to be a download failure, or a failure to install ReCap.  Both of those are easily fixable.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
If it still fails on ReCap, then choose not to install it at first.  Let the installation finish.  Then install it afterwards if desired.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
