Switch Systems and Circuits: 3way switch in a system. Multi Sw Sys on Circuit.
Allow me to connect a switch to a circuit.  Then any lights (or outlets/fixtures) connected that switch would automatically be part of the same circuit.  Multiple switch systems should be allowed on one circuit.
A switch system should allow for 3 & 4 way switches.
The project I'm currently working on has a circuit with two "ALWAYS HOT" lights, a normal switch with one light attached and a pair of 3 way switches controlling several lights.  Which basically means that I need to show the wiring from the ALWAYS HOT fixtures to the regular switch then to one of the 3-way switches and then the home-run pointing to the Panel.
I need to graphically show a wire going from each 3-way switch to one of the lights and a wire going from the regular switch to the one light it has attached.
3 Comments
doni49
I meant to say that I was able to get my plan showing this by manually drawing the wires but it's definitely not BIM as there's no intelligence in the file indicating these connections.
jeanmarc.couffin
jeanmarc.couffin
